Re: questions on putting my 70 road runner on a rotisserie
[Re: GI Moparman]
#1592260
03/13/14 12:01 PM
03/13/14 12:01 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
No, no, no. Do not change large sheet metal panels while the vehicle is on the Rotisserie. Especially quarter panels.
Master, again and still
[Re: DaveRS23]
#1592261
03/13/14 12:16 PM
03/13/14 12:16 PM
Posts: 5,948 British Columbia
chrisf
British Columbia
I agree. I know of a demon that had quarters and a bunch of sheetmetal work done while on a rotisserie. nothing fits and it needs to be cut back apart now.
[Re: DaveRS23]
#1592262
03/13/14 12:18 PM
03/13/14 12:18 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
If you want the panels off for the blaster make youself a dolly to transport the shell to the blasters. When you get it home put it on a stable platform and replace your panels. After that go to the rotisserie for under side owrk ect. When doen with that return to the floor for bolt on panel alignment. The bodies actually flex quite a bit when suspended on a rotisserie.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: GI Moparman]
#1592266
03/13/14 03:09 PM
03/13/14 03:09 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I lower my rotisserie so the car is supported on jack stands when I do quarters and other larger panels. I wouldn't be transporting it either on just a rotisserie after panels are removed.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: GI Moparman]
#1592271
03/14/14 02:09 PM
03/14/14 02:09 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Just have the blaster hit the seams where you will be looking for spot welds on the panels you will be replacing. One benefit of this way is you get most of the sand out when you remove the panel plus it stays rigid for the transport
Driving modern convenience in classic beauty
[Re: GI Moparman]
#1592273
03/15/14 02:26 AM
03/15/14 02:26 AM
Posts: 2,489 Tracy, New Brunswick, Canada
magnumcharger
I have had my Charger on a rotisserie for several years with no ill effects. However, when it came time to replace the quarter panels and rockers, I determined that the only way to sustain the original dimensions of the car was to properly support it, and use the actual factory diagram for measurements. I built this rolling body jig, which is similar in style to the ones at the AMD restoration shop. Each of the vertical posts supports the body at key locations, relative to the factory drawing.
