Adaptors for larger brakes. #159124
11/30/08 01:26 PM
11/30/08 01:26 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I have a disc assembly from a '73-76 A-body that I'll be putting on my '71 B-body and I'd like to know if there's a way to upgrade?
Re: Adaptors for larger brakes. [Re: 1fastrunner] #159125
11/30/08 01:36 PM
11/30/08 01:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Only two sizes of rotors fit that I'm aware of. You can buy the brackets and step up to the larger rotors.
Not sure if anybody makes performance brake pads, but that may be another way to add stopping power.
Re: Adaptors for larger brakes. [Re: Neil] #159126
11/30/08 01:38 PM
11/30/08 01:38 PM
What brackets? Can I get them from a bone yard? if so what vehicles?
Thanks,
Re: Adaptors for larger brakes. [Re: 1fastrunner] #159127
11/30/08 01:43 PM
11/30/08 01:43 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You can find the adapters off junkyard cars or on ebay.
http://www.moparaction.com/Tech/archive.html
Re: Adaptors for larger brakes. [Re: 1fastrunner] #159128
11/30/08 02:27 PM
11/30/08 02:27 PM
RI
MOPARS6768 Offline
MOPARS6768  Offline
RI
I have pulled 2 sets at junk yards both were in 77' cordoba's
Re: Adaptors for larger brakes. *DELETED* [Re: Neil] #159129
11/30/08 03:20 PM
11/30/08 03:20 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Post deleted by moparts
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Adaptors for larger brakes. [Re: hemi71x] #159130
11/30/08 04:55 PM
11/30/08 04:55 PM
& you can get performance pads. I have the 10.87" stock slider 73 A setup(the smaller of the 2 factory sizes)with 76 A calipers which have a 5/32"(2.75" vs 2.60") larger bore than 73-75 calipers & it's very inadequate. I was wondering if I had done a bed in procedure if that would have made a big difference.I forgot what kind of pads I used but they ain't cutting it.
Re: Adaptors for larger brakes. [Re: RapidRobert] #159131
12/01/08 09:39 AM
12/01/08 09:39 AM
scratchnfotraction Offline
yes,caliper brackets and 12" rotors from a r-body
brackets bolts on the A-body spindle
mid 80s cop cars and gran furys,dippys,5ths are the R-bodys
Re: Adaptors for larger brakes. [Re: scratchnfotraction] #159132
12/01/08 01:22 PM
12/01/08 01:22 PM
I just scored a spindle assembly from a late model A-body that already has the adapters with the 11" rotors. I just need to figure out which side goes where.
Thanks,
Re: Adaptors for larger brakes. [Re: 1fastrunner] #159133
12/01/08 01:27 PM
12/01/08 01:27 PM
they'll go on eithe side depending if you want your calipers front or rear hung I would mount them on the opposite side of the brake line/hose bracket unless you need them rear mounted to clear a sway bar.
Re: Adaptors for larger brakes. [Re: RapidRobert] #159134
12/01/08 01:34 PM
12/01/08 01:34 PM
I have a factory sway bar,so the calipers should be on the rear side?
Thanks,
JIm
Re: Adaptors for larger brakes. [Re: 1fastrunner] #159135
12/01/08 03:22 PM
12/01/08 03:22 PM
you want them on the opposite side of where the hard line/hose bracket is just like the factory setup. IF you have to rear mount them because of sway bar clearance problems all is well if your brackets are in the front(I dont know B bodies) but if the bracket is in the rear & using a rear mounted caliper it MAY take a custom hose. With the tires on just go from lock to lock & check for clearance/interference. Other than that fit/function/alignment is the same. EDIT since you already have the smaller 10.87" setup for sure checkout some aftermarket pads & ask for 76 dart calipers for the bigger bores to get more front bias & follow their breakin procedure. I've been in vehicles where they took the time to do the breakin for the pads & it's quite a difference in stopping power.
Re: Adaptors for larger brakes. [Re: scratchnfotraction] #159136
12/01/08 04:37 PM
12/01/08 04:37 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
No, Dippys and 5ths are M-bodies. The R-body is the 79-81-ish St Regis, Newport and Gran Fury.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Adaptors for larger brakes. [Re: Fury Fan] #159137
12/01/08 05:01 PM
12/01/08 05:01 PM
my bad
you can find some of the M-bodys with the 12" rotors also then
Re: Adaptors for larger brakes. [Re: scratchnfotraction] #159138
12/01/08 05:36 PM
12/01/08 05:36 PM
AndyF Offline
AndyF  Offline
my bad
Not from the factory you can't. It is very possible that people upgraded their M body cars with 11.75 rotors since it is an easy swap but the factory never put the bigger rotors on any of the FMJ cars even though they could've. It would have been a great option for the factory to offer but Chrysler didn't really get into offering good brakes or good suspension packages for some reason.
Re: Adaptors for larger brakes. [Re: AndyF] #159139
12/01/08 05:58 PM
12/01/08 05:58 PM
I have the adapters from a '76 A-body for 11' rotors, will these be big enough? or should I keep looking for the larger adapters?
Re: Adaptors for larger brakes. [Re: 1fastrunner] #159140
12/01/08 06:31 PM
12/01/08 06:31 PM
Jim my I would find some of the larger adapters & 11&3/4" rotors. I know my 10.87"'s on a daily driver early A body ain't enough & the increase in the lever arm with some better pads & a breakin peocedure should make a heck of a difference for you.
Re: Adaptors for larger brakes. [Re: RapidRobert] #159141
12/01/08 07:06 PM
12/01/08 07:06 PM
yes get the larger bracket for the larger rotors
seemed I got a set off a dippy police car with the cop rims also
the last ones I got where 88 gran fury police car and got the 360 headed 318 4-v to boot,it was a slider cam with a roller block
the large rotors and 11"x 2.5 brakes,large bore wheel cyl on the back with the adapter for a large bore 79 truck 2 bolt alum mc worked killer on my 68 A-body manual brake car
I also cut some aluminized exast tube,1.5"-2" tube with an angle to make air scoops and cut a hole in the dust sheild below the ball joint,then welded them on,tucked up there and in the air stream for max cooling
worked great for cooling the front rotors while auto-xing
