adding an extra fuel fuel firter #1591380
03/11/14 10:57 AM
03/11/14 10:57 AM
Canada
Dons Dart Offline OP
Canada
IS it ok to install an inline fuel filter before my mechanical fuel pump and 1 after the pump?
Re: adding an extra fuel fuel firter [Re: Dons Dart] #1591381
03/11/14 11:33 AM
03/11/14 11:33 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No, only the sock in the tank should be used. It's much courser than a filter made to go after the pump.
Re: adding an extra fuel fuel firter [Re: Challenger 1] #1591382
03/11/14 12:04 PM
03/11/14 12:04 PM
Canada
Canada
Thank you.
Re: adding an extra fuel fuel firter [Re: Dons Dart] #1591383
03/11/14 10:01 PM
03/11/14 10:01 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
If the sock filter has been removed, you can use a 100 micron prefilter such as: http://www.robbmcperformance.com/products/filters.html
The filter after the pump is usually a 40 micron.
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: adding an extra fuel fuel firter [Re: RobbMc] #1591384
03/12/14 02:05 AM
03/12/14 02:05 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I removed the sock in my tank and use a 3/8 sending unit and a Fram cartrige type filter before my electric fuel pump and then have the metal inline filter at the carb. It runs 10.70's like that with no sign of any fuel starvation. I feel safer with a filter by my carb to make sure no grud can get in the carb even though the filter before the pump should catch everything. You can see the inline filter in this pic. Ron
Re: adding an extra fuel fuel firter [Re: 383man] #1591385
03/12/14 05:48 AM
03/12/14 05:48 AM
Cincinnati, Ohio
Cincinnati, Ohio
That "fram" filter is designed to go after the pump, Ron. It's a 5 micron filter!!, no wonder you have had vapor lock problems. Just saying and trying to help. Your killing your fuel pump sucking through a 5 micron filter, crazy.
Re: adding an extra fuel fuel firter [Re: Challenger 1] #1591386
03/12/14 10:44 AM
03/12/14 10:44 AM
Canada
Canada
No i have not removed the filter from after the pump,just want to see if there is any way to catch any more dirt, I plan on installing a brand new 670 holley i just bought.
Re: adding an extra fuel fuel firter [Re: 383man] #1591387
03/12/14 10:47 AM
03/12/14 10:47 AM
Canada
Canada
Thanks for the tip Ron,nice set up you have there.
Re: adding an extra fuel fuel firter [Re: Dons Dart] #1591388
03/12/14 03:59 PM
03/12/14 03:59 PM
Most paper element filters are 10 microns, I'm almost positive you can't get any better fuel filters than those I have used a 100 micron in line filter between the electric fuel pump and the tank after finding out the hard way that the 10 micron filter was to small to use thier I used a 10 micron filter after the pump after that
Re: adding an extra fuel fuel firter [Re: Cab_Burge] #1591389
03/12/14 04:23 PM
03/12/14 04:23 PM
Cincinnati, Ohio
Cincinnati, Ohio
According to Summit Racing, the Fram deal is as fine as 5 microns! web page
Re: adding an extra fuel fuel firter [Re: Challenger 1] #1591390
03/12/14 05:43 PM
03/12/14 05:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Its not actually the Fram brand but it looks like that kind. I see plenty of people run them before the pump all the time and this is pumping a ton of fuel. I never had a vapor lock problem as it was fuel boiling in the carb and running rich and loading up when it happened and it happened before I had that filter on it as that was one of the reasons I changed it to see if it makes a difference. They said it would work fine this way and it is supposed to be a 50 micron according to the speed shop where I bought it. I honestly dont remember the brand name as it was in a white box and has no name on the filter. It looks like the Fram filter but it does not say Fram on it as it has no name on it. I actually have not had any more problems since I put it on and went to a smaller air cleaner so it did not hold as much heat around the carb bowls. It ran the same 10.70's like this as when I had no filter before the pump but I did not like to leave it with no filter before the pump since I get pump gas. Ron
Re: adding an extra fuel fuel firter [Re: 383man] #1591391
03/12/14 06:06 PM
03/12/14 06:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
Might want to check for sure the micron rating of it. I'll bet you it's 10 microns which is no good for before the pump. Every canister fram look a like that I saw was 10 microns.
I have seen plenty of people run them too before the pump, don't make it right.
I did too, many years ago in the 80s. My car left me stranded too many times when I was running a electric pump, long before ethanol.
I figured out fuel flow when I went drag racing, have to, to go fast. Kinsler was my mentor and taught me all about fuel systems. I just try to share what I learned.
Re: adding an extra fuel fuel firter [Re: Challenger 1] #1591392
03/12/14 06:36 PM
03/12/14 06:36 PM
Canada
Canada
So what kind of filter would be best for just after my pump,right now I am using an G 15,wow never thought about microns,thanks bro.
Re: adding an extra fuel fuel firter [Re: Dons Dart] #1591393
03/12/14 06:48 PM
03/12/14 06:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
There are many choices today. I like steel housing filters for the street, as large as I can fit. The Fram deal at 5 or so microns is as fine as you can get and is steel and has a larger housing than most.
Robbmc above suggested some filters, you should check them out.
Kinsler always suggested there filters which were larger than most other's with more square inches of removable stainless screen inside, larger is better I believe.
Both my street cars are using a factory vapor separator for filters with no problems.
Re: adding an extra fuel fuel firter [Re: Challenger 1] #1591394
03/12/14 06:53 PM
03/12/14 06:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
All I can say is I have had no problems but I looked at some to see what brand it might be and it looks to be either an Aeromotive , Professional Products or Jegs. You are right as two of them say a 10 micron filter but the Aeromotive is does have a 100 micron filter in one of theirs. But none of them say before or after the pump. But if you are correct then I can look into the 100 micron filter and be sure it will work good. Thanks , Ron
Re: adding an extra fuel fuel firter [Re: 383man] #1591395
03/12/14 07:06 PM
03/12/14 07:06 PM
Canada
Canada
So how good does the G15 scores?
Re: adding an extra fuel fuel firter [Re: 383man] #1591396
03/12/14 07:07 PM
03/12/14 07:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
don't use any cellulose type filters on the suction side of a pump. high micron screens can work on the suction side. ron, if you can take your filter apart look to see if there's a screen in it.
Re: adding an extra fuel fuel firter [Re: Dons Dart] #1591397
03/12/14 10:30 PM
03/12/14 10:30 PM
Cincinnati, Ohio
Cincinnati, Ohio
Got a link or a picture of the G15?
Re: adding an extra fuel fuel firter [Re: Challenger 1] #1591398
03/13/14 10:37 AM
03/13/14 10:37 AM
Canada
Canada
Got a link or a picture of the G15? Sorry no pic, just type fram G 15 it will come up.thanks for the help.
Re: adding an extra fuel fuel firter [Re: Dons Dart] #1591399
03/13/14 10:45 AM
03/13/14 10:45 AM
Cincinnati, Ohio
Cincinnati, Ohio
Found it, Yes I have run that filter and see no problem with it. Should do the job just fine.
