Fab 8 3/4 opinions? #1591231
03/10/14 09:09 PM
03/10/14 09:09 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
What's everyone thaught on the housing living in a 3200+ lbs car running mid low 8s
Looking at the new centers also, Yukon or Aluminum?
I have had zero problems as of yet only bent housings, back brace fixed that.
Would like to just swap everything over to a stronger housing and center.
Re: Fab 8 3/4 opinions? [Re: RockChip] #1591232
03/10/14 09:44 PM
03/10/14 09:44 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I run in the eights with a 8 3/4 in my car, back braced,spool, 35 spline axles. I am at 3225 and it has lived for a lot of years so far. But I only 60ft 1.35 so it's not hitting the tires that hard.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Fab 8 3/4 opinions? [Re: RockChip] #1591233
03/11/14 01:17 AM
03/11/14 01:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I run one haven't been in the 8's with it but i have had a best 60'of 1.28 with a [Email]29.5x10.5@3350lbs.
Re: Fab 8 3/4 opinions? [Re: racerx] #1591234
03/11/14 01:29 AM
03/11/14 01:29 AM
Mo.
racerx Offline
racerx  Offline
Mo.
What do the car weigh at rw?Nevermind i miss it in the frist post
Re: Fab 8 3/4 opinions? [Re: RockChip] #1591235
03/11/14 01:31 AM
03/11/14 01:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have a back braced housing then your fine there...
you wont break that part... I'm still running my back
braced housing running in the 8s with a alum center
but in a light car with a 1.19 60'
Re: Fab 8 3/4 opinions? [Re: MR_P_BODY] #1591236
03/11/14 07:11 PM
03/11/14 07:11 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I've been 1.24 60' in a 2750 SB 5.66 1/8. 8 3/4 w/ all the tricks except an alunimium housing. I've grown REAL tired of breaking stuff!I'm hoping to be switching to a dana soon.Broken parts break hearts and budgets too!
Re: Fab 8 3/4 opinions? [Re: DavidDean] #1591237
03/11/14 10:16 PM
03/11/14 10:16 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I'm hopping to get my car down to 3200 but it's probably gonna be 3300.
So is the Aluminum center better than the new iron one from like Yukon or so?
Seen a pic of a iron one that looked really heavy duty, outside appearance didn't resemble much what the normal look like.
Anyone know who makes the heavy one?
Re: Fab 8 3/4 opinions? [Re: RockChip] #1591238
03/11/14 10:21 PM
03/11/14 10:21 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Think Doctordiff sells the nodular one
Re: Fab 8 3/4 opinions? [Re: racerx] #1591239
03/12/14 12:25 AM
03/12/14 12:25 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Whose housing is that?
Been tossing around what to do with my 8.75
Strange axle's & spool, stock housing, no back brace and stock caps & bolts = not gonna live long
Re: Fab 8 3/4 opinions? [Re: roadhazard] #1591240
03/12/14 12:27 AM
03/12/14 12:27 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Moser...............
Re: Fab 8 3/4 opinions? [Re: racerx] #1591241
03/12/14 12:33 AM
03/12/14 12:33 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thank You.............
