Re: draining gastank
[Re: bonefish]
#1590912
03/10/14 03:13 PM
03/10/14 03:13 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Does it smell like bad gas? If it doesn't smell sour you may be able to just run it out.
If your worried about varnish and crud, drop the tank and drain it.
You could even use the electric fuel pump to pump it out, but then your still running bad gas, and sucking varnish or whatever into the pump/filter.Or filter screen if it hasn't deteriorated
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1590913
03/10/14 04:56 PM
03/10/14 04:56 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
No elect pump.i was able to find a line under the engine to drain it but boy is it SLOOOW! And O YEH it smells FUNKY.
[Re: bonefish]
#1590914
03/10/14 08:14 PM
03/10/14 08:14 PM
hp383
State of Confusion
If you remove the filler cap it may drain a bit faster.
[Re: hp383]
#1590915
03/10/14 09:34 PM
03/10/14 09:34 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
first thing i did.
[Re: 85_Ram_4speed]
#1590917
03/12/14 06:51 PM
03/12/14 06:51 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Be patient or go buy a super cheap electric universal pump and pump and hook it up at the fuel line that goes from the frame to engine. That is the easiest way to do it.
That's what I did with my 28 gal. tank yesterday. Worked perfect! I pulled the filler hose off the body filler neck, and ran the pump hose in there. Good luck.
