Carb change #1590177
03/08/14 10:31 PM
03/08/14 10:31 PM
S.e. lower MIch..
66droptop Offline OP
S.e. lower MIch..
1966 Coronet 318 poly.Stock except for a rebuild in 2004,just put hardened seats in.I have a carter bbd 1 1/4 on it now but it is leaking and old.Instead of having it rebuilt I am considering buying a new carb.Not looking to upgrade for more power just looking for a replacement.What is a good choice.Thanx
Re: Carb change [Re: 66droptop] #1590178
03/08/14 11:07 PM
03/08/14 11:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
not sure you can still buy a brand new carb that bolts to the BBD pattern intake.
Don't be the exception.
Re: Carb change [Re: 66droptop] #1590179
03/09/14 12:31 AM
03/09/14 12:31 AM
Where is it leaking? You could rebuild it for cheap or even just replace the parts that are leaking: needle/seat, top gasket & if desired you could flush it out with some brake kleen in lieu of soaking it if you dont have the soup. eBay might have something for you
Re: Carb change [Re: RapidRobert] #1590180
03/09/14 08:51 PM
03/09/14 08:51 PM
S.e. lower MIch..
S.e. lower MIch..
I'll post a pic monday.
Re: Carb change [Re: 66droptop] #1590181
03/09/14 09:04 PM
03/09/14 09:04 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
BBD's are very easy to work on. A gallon of carb dip, some spray carb cleaner, and a rebuilt kit (and maybe a float) would take care of it.
Or, just hit up your choice of parts stores and they will probably have a re-manufactured one in the system.
If it is an original carb and you go the re-manufactured route, then keep your original and just pay the core charge. You might want it later down the road.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Carb change [Re: Michael Ecks] #1590182
04/12/14 10:14 PM
04/12/14 10:14 PM
S.e. lower MIch..
S.e. lower MIch..
So here are 2 pics.I think I might replace a couple of gaskets as the carb has given me no problems except for the leak.I had a parts diagram and list for this carb but can't seem to find.Any info would be appreciated.
OK.My pics are to large.Must figure how to resize???
Re: Carb change [Re: 66droptop] #1590183
04/12/14 11:33 PM
04/12/14 11:33 PM
I figured out I had to change the pixel? setting on my camera before I took the pics so the pics would load. I ain't a camera guy but I can say that they look just as clear as the larger pixel ones I have stored as far as I can tell. read your camera instruction manual or online
Re: Carb change [Re: RapidRobert] #1590184
04/13/14 01:49 PM
04/13/14 01:49 PM
S.e. lower MIch..
S.e. lower MIch..
try these...
Re: Carb change [Re: 66droptop] #1590185
04/13/14 01:49 PM
04/13/14 01:49 PM
S.e. lower MIch..
S.e. lower MIch..
2
Re: Carb change [Re: 66droptop] #1590186
04/13/14 02:00 PM
04/13/14 02:00 PM
It's definitely leaking out of the top AP hole in the top casting. I would open it up & get the kit (they're cheap) & just add the needle/seat and the new top gasket & reset the float level & replace the AP plunger & call it good without removeing the carb & soaking it & all that. I twirl the needle inbetween my thumb and forefinger to smooth the tapered neoprene part for a better seal & lube the bowl screws to make it less likely they will strip the alum casting if you are in & out of there repeatedly which you wouldn't be with this carb like you would with a carb that you were doing alot of jet changes but it's a good habit to get into. EDIT I would also lightly spray the bowl gasket with WD40 on both sides which helps preserve the gasket if you're back in & out of there several times
Re: Carb change [Re: RapidRobert] #1590187
04/13/14 08:23 PM
04/13/14 08:23 PM
S.e. lower MIch..
S.e. lower MIch..
I need a kit number.A diagram of the parts would be helpfull also.Thanx
Re: Carb change [Re: 66droptop] #1590188
04/13/14 10:18 PM
04/13/14 10:18 PM
I'm assuming the aluminum tag under one of the top bolts is missing. See if there is a number on the base. If not then likely 1 kit covers alot of those years of carter BBD's. Talk to your parts man. When you get to that point open up the carb & holler back & I'll help you thru it if needed
Re: Carb change [Re: 66droptop] #1590189
04/13/14 10:27 PM
04/13/14 10:27 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
American Carburetor Services
23325 Harper Ave, St Clair Shores, MI 48080
(586) 772-6282
Re: Carb change [Re: RSNOMO] #1590190
04/14/14 01:39 PM
04/14/14 01:39 PM
dogdays Offline
dogdays  Offline
I believe there is a rebuilt one on the 'bay right now.
I hated mine, the float would stick open and spray gas all over the engine. No matter how many times I had it apart I couldn't get it to stop that. Also, it was nearly impossible to find smaller main jets for it although I finally did around the time I switched to the Weiand 7503 and the Holley 1850. They were used on Avantis and the Avanti owners group is a source for jets.
R.
Re: Carb change [Re: dogdays] #1590191
04/25/14 11:53 PM
04/25/14 11:53 PM
S.e. lower MIch..
S.e. lower MIch..
So RapidRobert I am about to clean up the carb on Saturday...I never heard about the wd40 mmove but i'll try it..Just need to set the float,thats the hardest part for me....
Re: Carb change [Re: 66droptop] #1590192
04/26/14 12:29 AM
04/26/14 12:29 AM
new needle/seat/seat gasket installed with the outside nut tightened to its final amount. I'd go ahead & have the short fuel line nipple tightened to its final position also so you dont have to tighten the seat anymore which changes the float cuz it moves the tang. float already installed before the needle/seat installation. The U shaped piece in place & hold it in position. Carb level. fill the bowl with gas. set the gauge across the floats on top & bend the tang as needed to get the float level within a 1/32" of specs. with the needle closed ideally you want the tang to contact the needle at a 90 deg angle or pretty close to it for the best leverage
Re: Carb change [Re: RapidRobert] #1590193
05/31/14 12:22 AM
05/31/14 12:22 AM
S.e. lower MIch..
S.e. lower MIch..
I got the carb cleaned and put new gaskets thru out.New needle and seat,new float.Took a few times to get the float right but it seems good to go.Gas mileage back up to around 17 mpg,Happy...BUT,since I replace the gaskets and put back together I get a hissing noise from the carb,it changes as the throttle is moved.It sounds like a vaccum leak but the car is running good,hooked up a vaccum gauge got plenty of vaccum.I started the car with the top bowl of the carb off,saw it on youtube,If I cover up the venturi area thats where the hissing is coming from.What do you think....
Re: Carb change [Re: 66droptop] #1590194
05/31/14 01:08 AM
05/31/14 01:08 AM
Not sure. I have heard that on some carbs so you might be OK. Sounds like the mileage/driveability is excellent. EDIT I'm thinking I've heard that with 2 bbl carbs with fairly high vac numbers which you very likely have. I'd say you're good unless someone advizes otherwise
Re: Carb change [Re: RapidRobert] #1590195
05/31/14 09:38 AM
05/31/14 09:38 AM
S.e. lower MIch..
S.e. lower MIch..
Thanx RapidRobert for your response and help.Just saying that I never had this sound before.
