904 vs 727 driveshaft length difference #1589883
03/08/14 12:05 PM
03/08/14 12:05 PM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
went to virginia from detroit to pick up a car,904 trans let loose in the truck when I got there. $1600 for a rebuild, no old parts in the salvage yards .forget it. back home in detroit,I am going to upgrade to a 727 trans, so I need to get everything ready for a quick swap next weekend.i have the 727 yoke, how much to shorten the driveshaft? 904 trans is in vehicle,727 is it's replacement.
Re: 904 vs 727 driveshaft length difference [Re: moretoys] #1589884
03/08/14 03:01 PM
03/08/14 03:01 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
This trans length info was posted a few years ago by member Feets. It should help but I don't know if the different slip yokes make a difference. Hopefully someone with more knowledge will chime in.
Re: 904 vs 727 driveshaft length difference [Re: moparfan53] #1589885
03/08/14 07:07 PM
03/08/14 07:07 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
A 727 is 4" longer than a 904.... So going from 904 to 727 you're driveshaft needs shortened 4"
Re: 904 vs 727 driveshaft length difference [Re: moretoys] #1589886
03/08/14 10:00 PM
03/08/14 10:00 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The driveshaft lengths are listed in the White Books, so if you just list what car and rear end you have it will be real easy. Also, there are different diameters depending on your combination.
JB Rhinehart, Realist
A-Body's RULE!
Re: 904 vs 727 driveshaft length difference [Re: Rhinodart] #1589887
03/08/14 10:14 PM
03/08/14 10:14 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Do yourself a favor and install the driveshaft yoke into the tail of the trans, push it in till it bottoms out.
Pull it back out 3/4 to 1" from it's bottomed out position in the tail of the trans and measure from the center of the ujoint cup on the front of the drivshaft to the center of the yoke that the rear ujoint sets in and that would be your length.
You can just cut 4" off but you might want to check the actual length.
Once it to short its gonna stay that way.
You will want to do this with the cars rear end on jack stands not with the rear end hanging..
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 904 vs 727 driveshaft length difference [Re: BB65Barracuda] #1589888
03/09/14 11:35 AM
03/09/14 11:35 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I have had 3 drive shafts shortened for different cars. the older car drive shafts can not be shortened. they are double wrapped, meaning there is an inner shaft, a layer of vibration dampening rubber and then another tube on the outside. the easiest thing to do is get a drive shaft from a 70's/80`s truck or van and have it shortened. although they are larger in diameter, they are not double wrapped and can be shortened.
*sorry I just reread that you are swapping trans. in a truck
Re: 904 vs 727 driveshaft length difference [Re: 65rbdodge] #1589889
03/09/14 10:11 PM
03/09/14 10:11 PM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
I have a spare driveshaft, and I'll get it cut down, can't do the measure thing, the truck is 9 hours away and I need to drive there friday night, swap the trans out saturday, drive home sunday. I don't see getting a driveshaft done in a couple hours.Thanks,
Re: 904 vs 727 driveshaft length difference "update" [Re: moretoys] #1589890
03/26/14 12:35 AM
03/26/14 12:35 AM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
For what it's worth, I had 4 inchs cut off the driveshaft, and all is fine,made it back to michigan. Thanks.
