Re: 904 vs 727 driveshaft length difference
[Re: Rhinodart]
#1589887
03/08/14 09:14 PM
03/08/14 09:14 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Do yourself a favor and install the driveshaft yoke into the tail of the trans, push it in till it bottoms out. Pull it back out 3/4 to 1" from it's bottomed out position in the tail of the trans and measure from the center of the ujoint cup on the front of the drivshaft to the center of the yoke that the rear ujoint sets in and that would be your length. You can just cut 4" off but you might want to check the actual length. Once it to short its gonna stay that way. You will want to do this with the cars rear end on jack stands not with the rear end hanging..
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: 65rbdodge]
#1589889
03/09/14 09:11 PM
03/09/14 09:11 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
I have a spare driveshaft, and I'll get it cut down, can't do the measure thing, the truck is 9 hours away and I need to drive there friday night, swap the trans out saturday, drive home sunday. I don't see getting a driveshaft done in a couple hours.Thanks,
