Cometic Head gaskets #1589718
03/07/14 11:09 PM
03/07/14 11:09 PM
Colorado Springs, Colorado
cool70cuda Offline OP
Has anyone used Cometic head gaskets and had problems with coolant leaks? I'm using them with a cast block and Indy heads. Thanks
Re: Cometic Head gaskets [Re: cool70cuda] #1589719
03/07/14 11:18 PM
03/07/14 11:18 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I never had a leak. 50ra finish on the deck & heads. Copper coat all 6 sides of the gaskets & ur good.
Re: Cometic Head gaskets [Re: cool70cuda] #1589720
03/08/14 12:46 AM
03/08/14 12:46 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
They leaked on my small block, dry install, proper finish. I added stop leak 5 years ago and it was never an issue again. My big block w/Indys. Same deal dry, proper finish, no leaks w/o stop leak. Reused the BB w/copper spray, no leaks.
Doug
Re: Cometic Head gaskets [Re: cool70cuda] #1589721
03/08/14 02:19 AM
03/08/14 02:19 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes have had some issues but a mechanic in a bottle(stop leak)always fixed it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Cometic Head gaskets [Re: 1967dartgt] #1589722
03/08/14 01:45 PM
03/08/14 01:45 PM
Archbald, PA
N
Newbomb_Turk Offline
N
Archbald, PA
I know several people that had leak issues, Cometic tells you to install dry, DON'T DO IT!! Like in other responses, copper coat spray all sides, between gaskets, and never a leak, worked for me!
1971 Demon 440 auto Drag car full tub, Best 10.47 @ 126
Re: Cometic Head gaskets [Re: cool70cuda] #1589723
03/08/14 02:38 PM
03/08/14 02:38 PM
Penna
70satelliteguy Offline
Penna
Just also be careful that none of the rivets that hold the cometics together interfere with the block and the heads. I had problems with this with indy heads(572-13 heads) and my megablock. EspeciallyThe bottom rivet(near exhaust ports) .
Re: Cometic Head gaskets [Re: 70satelliteguy] #1589724
03/09/14 03:50 AM
03/09/14 03:50 AM
As already pointed out the proper finish is the key to them sealing dry, with no problems I've done it more than several times in the last four years. No Coppercoat needed if your parts are finish correctly
Re: Cometic Head gaskets [Re: Cab_Burge] #1589725
03/12/14 12:24 AM
03/12/14 12:24 AM
Thanks for the responses. We had the engine running and it was leaking from the head gaskets. Had installed them with copper coat and no obstructions. Ended up using BG coolant sealer and after a few heat cycles and a long drive, the leak is gone.
