Questions about my 18 spline A-833 4 speed. #1589412
03/07/14 10:01 PM
03/07/14 10:01 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Anyone who can help. Is this the correct shift levers for my 18 spline A-833 4 speed?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589413
03/07/14 10:04 PM
03/07/14 10:04 PM
Dreaming of the 808
Dreaming of the 808
Also, someone at one time ground off the tip of the input shaft, using a straight edge it still protrudes about 1 1/8 inch past the bell housing. Is it usable without repairing or replacing the input shaft?
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589414
03/07/14 10:15 PM
03/07/14 10:15 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Input shaft is fine. It that an overdrive tranny? They have the 3/4 lever upside down like that.
Re: Questions about my 18 spline A-833 4 speed. [Re: fastmark] #1589415
03/07/14 10:19 PM
03/07/14 10:19 PM
Dreaming of the 808
Dreaming of the 808
It might have just been put on wrong, I have never used it to drive and this is the way I got it 20 years ago.
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589416
03/07/14 10:21 PM
03/07/14 10:21 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Look on Brewers website. they may have pictures. It's hard to say with out being able to see the numbers on the levers.
Re: Questions about my 18 spline A-833 4 speed. [Re: fastmark] #1589417
03/07/14 10:28 PM
03/07/14 10:28 PM
Dreaming of the 808
Dreaming of the 808
I got this from Phil Newcomb before he disappeared. Numbers on the levers are 068 or 890, 967 and 891. I will pull the levers off the trans and post the numbers.
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589418
03/08/14 03:30 PM
03/08/14 03:30 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
The 3 numbers on the levers are the last 3 digits of the part number. All 3 numbers, 2892890 (3rd & 4th), 2892891 (low & 2nd), & 2892967 (reverse) are found in the 1970-71 parts book. They show as fitting B & E bodies 18 Spline transmissions. The 890 & 891 also fit 1968-69 B bodies.
That's as far as I checked.
Re: Questions about my 18 spline A-833 4 speed. [Re: twodoorpost] #1589419
03/08/14 03:36 PM
03/08/14 03:36 PM
Dreaming of the 808
Dreaming of the 808
Looks like the reverse lever is the only incorrect one after I blasted them clean and can read the numbers.
