Questions about my 18 spline A-833 4 speed. #1589412
03/07/14 10:01 PM
03/07/14 10:01 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Anyone who can help. Is this the correct shift levers for my 18 spline A-833 4 speed?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589413
03/07/14 10:04 PM
03/07/14 10:04 PM
Dreaming of the 808
Dreaming of the 808
Also, someone at one time ground off the tip of the input shaft, using a straight edge it still protrudes about 1 1/8 inch past the bell housing. Is it usable without repairing or replacing the input shaft?
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589414
03/07/14 10:15 PM
03/07/14 10:15 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Input shaft is fine. It that an overdrive tranny? They have the 3/4 lever upside down like that.
Re: Questions about my 18 spline A-833 4 speed. [Re: fastmark] #1589415
03/07/14 10:19 PM
03/07/14 10:19 PM
Dreaming of the 808
Dreaming of the 808
It might have just been put on wrong, I have never used it to drive and this is the way I got it 20 years ago.
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589416
03/07/14 10:21 PM
03/07/14 10:21 PM
Abilene, Texas
Abilene, Texas
Look on Brewers website. they may have pictures. It's hard to say with out being able to see the numbers on the levers.
Re: Questions about my 18 spline A-833 4 speed. [Re: fastmark] #1589417
03/07/14 10:28 PM
03/07/14 10:28 PM
Dreaming of the 808
Dreaming of the 808
I got this from Phil Newcomb before he disappeared. Numbers on the levers are 068 or 890, 967 and 891. I will pull the levers off the trans and post the numbers.
Re: Questions about my 18 spline A-833 4 speed. [Re: AZ_A12_BEE] #1589418
03/08/14 03:30 PM
03/08/14 03:30 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
The 3 numbers on the levers are the last 3 digits of the part number. All 3 numbers, 2892890 (3rd & 4th), 2892891 (low & 2nd), & 2892967 (reverse) are found in the 1970-71 parts book. They show as fitting B & E bodies 18 Spline transmissions. The 890 & 891 also fit 1968-69 B bodies.
That's as far as I checked.
Re: Questions about my 18 spline A-833 4 speed. [Re: twodoorpost] #1589419
03/08/14 03:36 PM
03/08/14 03:36 PM
Dreaming of the 808
Dreaming of the 808
Looks like the reverse lever is the only incorrect one after I blasted them clean and can read the numbers.
