Re: thickness; '69/earlier 440 forged steel versus 426 HEMI [Re: JohnRR] #1589259
03/11/14 09:36 PM
03/11/14 09:36 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
But the hemi pistons are heavier than the wedge pistons.
And added to the mix is he used 440 rods which are shorter than hemi rods so he either has a heavier piston because it is .100 or so taller , or he has lower compression because the piston isn't up as high as it should be ... unless he used a 12.0 piston ? then there was the weight added to the crank to balance for a hemi ???
Lower compression would be the correct answer............. and my hairdresser is impressed............. Oh wait, I don't have one of those........
Troy
Houston Mopar Connection Club
Re: thickness; '69/earlier 440 forged steel versus 426 HEMI [Re: hemi68charger] #1589260
03/12/14 08:19 PM
03/12/14 08:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I bet the guy used stock hemi rods and pistons on the 440 crank. I hope the guy rebalanced the crank too! If you are trying to make it look correct, use the hemi balancer, it'll cost the same to make a spacer. Its just bolt on and go(a longer bolt is needed).
Re: thickness; '69/earlier 440 forged steel versus 426 HEMI [Re: hemi68charger] #1589261
03/12/14 08:37 PM
03/12/14 08:37 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I would suggest finding out just what you have. Then if I remember what you said you have Hemi pullies, right? You can get a Pro Race brand blancher that is the same thickness as a Hemi one. They are better, and after it is painted you really can't tell the difference. Thats what I did.
Re: thickness; '69/earlier 440 forged steel versus 426 HEMI [Re: 71birdJ68] #1589262
03/13/14 11:12 AM
03/13/14 11:12 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have that balancer for my hemi , painted it will look somewhat correct but it has wedge depth hub , will still need the spacer.
Re: thickness; '69/earlier 440 forged steel versus 426 HEMI [Re: JRepucci] #1589263
03/13/14 01:18 PM
03/13/14 01:18 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
The difference between the 2 measurements is 11/16...give or take the tongue on a metal tape measure 3/4 would suffice.
So what is the dimension of the thick part of the hemi balancer or the part that is visual? And what is the dimension of the 440 balancer that was referenced?
Al & Sheila
Re: thickness; '69/earlier 440 forged steel versus 426 HEMI [Re: 3twos] #1589264
03/13/14 05:15 PM
03/13/14 05:15 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Wedge 15/16"
Hemi 1-5/8"
Pictured is a factory dimensioned Hemi balancer that is fully degreed..Ive had it for 25 years..Prob an old DC piece..
MB
