Re: Sway Bar Brackets
[Re: jt4406]
#1589234
03/07/14 06:20 PM
03/07/14 06:20 PM
Posts: 1,567 Ky
jt4406
Ky
You will need the brackets that the sway bar bushing brackets bolt to. They bolt to the k member. You should also check to make sure that your k member will accept the 70 model swaybar, I believe some of the earlier ones will not. just my jess
Yeah, it's hopped up to over 160...
[Re: jimm69]
#1589237
03/07/14 09:24 PM
03/07/14 09:24 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Thanks Jess. Those are the brackets I was told to get and weld on to my lower control arms.
Do you have the right K frame ? 69 can have 2 different style K frames depending on when it was built during the model year , one will accept a 70 swaybar the other will not with you hacking huge holes in it .
I was going to ask Why again ... but nevermind ...
[Re: JohnRR]
#1589238
03/08/14 12:23 AM
03/08/14 12:23 AM
Posts: 252 Seattle, WA.
edp
Seattle, WA.
these are Hotchkis sway bar tabs I bought & welded on, they worked out great. Its on my 71, not sure how much different a sway bar setup is on a 70 but this what they are. hope this helps. E [image] [/image] [image] [/image] [image] [/image]
