Re: Leak Free Rear Main Seal 440 Is It Possible???????
[Re: Stewpar]
#1589159
03/07/14 03:18 PM
03/07/14 03:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
My biggest pet peave, does anyone have a solution???? Thank you!
I purchase a rear seal based on the crank's finish in the seal area, if it's knurled, rope seal only, if it's smooth, Viton rubber seal or rope, but prefer the rubber seal on a smooth crank surface, if you go rubber, "clock" the parting lines of the seal offset in it's "bore", not flush with the parting lines of the block/cap as mentioned in the above post
mike
[Re: Pacnorthcuda]
#1589161
03/08/14 01:08 AM
03/08/14 01:08 AM
Posts: 1,177 People's Republic of Kali
70runner
The last two I did were leak free. Use the orange Viton seals. Offset the split slightly from the retainer cap split.
Used 440source kit with OE main seal housing. Offset is key. 440-6 build, rear main spotless for 15mos. 727 does dribble through the pivot hole tho
