Leak Free Rear Main Seal 440 Is It Possible??????? #1589155
03/07/14 12:47 PM
03/07/14 12:47 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
My biggest pet peave, does anyone have a solution???? Thank you!
Admiration For Multiple Carburetor Vehicles...
Re: Leak Free Rear Main Seal 440 Is It Possible??????? [Re: Stewpar] #1589156
03/07/14 01:32 PM
03/07/14 01:32 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
The last two I did were leak free. Use the orange Viton seals. Offset the split slightly from the retainer cap split.
Re: Leak Free Rear Main Seal 440 Is It Possible??????? [Re: Pacnorthcuda] #1589157
03/07/14 01:50 PM
03/07/14 01:50 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Where did you get them from?
Re: Leak Free Rear Main Seal 440 Is It Possible??????? [Re: Stewpar] #1589158
03/07/14 02:28 PM
03/07/14 02:28 PM
440source sells them, ebay has them, there's someone on Moparts too. Google it, they are not hard to find. Don't do the screwy silicone and pipe cleaner method for the sides of the retainer, use the rubber strip method.
Re: Leak Free Rear Main Seal 440 Is It Possible??????? [Re: Stewpar] #1589159
03/07/14 03:18 PM
03/07/14 03:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I purchase a rear seal based on the crank's finish in the seal area, if it's knurled, rope seal only, if it's smooth, Viton rubber seal or rope, but prefer the rubber seal on a smooth crank surface, if you go rubber, "clock" the parting lines of the seal offset in it's "bore", not flush with the parting lines of the block/cap as mentioned in the above post
mike
Re: Leak Free Rear Main Seal 440 Is It Possible??????? [Re: DAYCLONA] #1589160
03/07/14 06:04 PM
03/07/14 06:04 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Re: Leak Free Rear Main Seal 440 Is It Possible??????? [Re: Pacnorthcuda] #1589161
03/08/14 01:08 AM
03/08/14 01:08 AM
People's Republic of Kali
70runner Offline
70runner  Offline
Used 440source kit with OE main seal housing. Offset is key. 440-6 build, rear main spotless for 15mos. 727 does dribble through the pivot hole tho
