Which Intake RPM Air Gap Or Super Victor. #1587877
03/04/14 12:03 AM
03/04/14 12:03 AM
dusterjp Offline OP
dusterjp  Offline OP
Not sure which intake is best for me. I have gone back and forth and can't decide If I should use an RPM Air Gap (ported) or a Super Victor. Here is my combo. 70 Plymouth Duster 418 CI small block. Mild ported Edelbrock heads. 10.9 to 1 compression. Solid flat tappet Comp Cam - @ .050 intake 254 exhaust 262 - lobe separation 108 installed @ 106.5 - lift intake .540 exhaust .555. Pro Systems Carb 837 cfm. 4 sod. - 3.91 gear. This car is always street driven. All opinions welcome and appreciated.
Does anyone know if the Air Gap responds well to porting?
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587878
03/04/14 12:10 AM
03/04/14 12:10 AM
Az
Crizila Offline
Crizila  Offline
Az
Thanks.
Street driven and 3.91 gear = air gap - or maybe 340 Victor Jr.
Fastest 300
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587879
03/04/14 12:11 AM
03/04/14 12:11 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Your combo would love a ported Victor intake.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587880
03/04/14 12:24 AM
03/04/14 12:24 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't think you need an air gap, never ran a super victor but do have a victor 340 on my 408. My cam is 260/264, .526/.533, 10.9-1 compression with ported edelbrocks and 4.10 gears. It pulls from anywhere in the rpm range and yours should too. I'd go with a single plane, victor 340 or a weiand x-cellerator.
Re: Which Intake RPM Air Gap Or Super Victor. [Re: justinp61] #1587881
03/04/14 02:08 AM
03/04/14 02:08 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
The air-gap will perform a lot better than most think on that combo. You will have more low to mid range and a slight loss up top, but not enough to justify changing it.
I feel that a super victor is probably too big for your combo.
A standard victor or an m1 would be my 1st choice. But the rpm will be a good intake. Many will argue, but they haven't tried it to know that it works better than expected.
Re: Which Intake RPM Air Gap Or Super Victor. [Re: viperblue72] #1587882
03/04/14 10:43 AM
03/04/14 10:43 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I have run both the Airgap and the Victor on my stroker. Both ran very well. For a street car I would use the Airgap, the response was a little crisper, and it had a little more torque (which is what a street car needs). The Victor also worked great (this is curretly what is on my car). It made a little more top end horse power (about 1.5 MPH faster in the 1/8 mile). The Super Victor is probably too big for what you have.
For what its worth, my stroker has gone 10.89 @ 122 MPH with the Airgap, so I don't think it will be holding you back much, if any.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587883
03/04/14 12:02 PM
03/04/14 12:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have tried 4 different manifolds on my hot 340. I started years ago with a single plane wieiand. Then tried the dual plane and was not happy with it, it didn't pull up top like I was used to. Then I tried a dual plane RPM manifold and it still didn't have the power that single plane had. So then I tried a M-1 manifold and it was beeter than the dual plane but not as good as a the original weiand single plane. Then I got a Victor JR 340 and it is almost the manifold that the original weiand was.
So I think the victor JR 340 is the best for a stroker sb.
Why would you need a dual plane for tork on the street when your running a stroker sb that's supposed to have more torq than my stock stroke 340?
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587884
03/04/14 01:08 PM
03/04/14 01:08 PM
Oakland, MI
dizuster Online content
dizuster  Online Content
Oakland, MI
With the 4 speed, I'd definately put the Air Gap on it. If it was an auto with a loose converter I'd say Victor 340, but the stick will lug the RPM down far enough that the Air Gap will feel "stronger" down low.
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587885
03/04/14 01:24 PM
03/04/14 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Airgap for a street car... you want the torque
Re: Which Intake RPM Air Gap Or Super Victor. [Re: MR_P_BODY] #1587886
03/04/14 08:53 PM
03/04/14 08:53 PM
dusterjp Offline OP
dusterjp  Offline OP
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587887
03/04/14 09:04 PM
03/04/14 09:04 PM
Renton Washington
Triple Threat Offline
Renton Washington
Air Gap. I've had both.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587888
03/04/14 09:08 PM
03/04/14 09:08 PM
PA.
"Little"John
"Little"John
PA.
Here's some reading on some tests I did.
https://board.moparts.org/ubbthreads/showflat.php?Number=7118476
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Which Intake RPM Air Gap Or Super Victor. [Re: pittsburghracer] #1587889
03/05/14 12:32 AM
03/05/14 12:32 AM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
Street car AIRGAP
Re: Which Intake RPM Air Gap Or Super Victor. [Re: CRIKEY] #1587890
03/07/14 11:06 PM
03/07/14 11:06 PM
dusterjp Offline OP
dusterjp  Offline OP
Looks like it's the Air Gap. Thanks everyone!
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587891
03/08/14 12:22 AM
03/08/14 12:22 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I run the M-1 Single plane on my 408. Don't know if it's as good, worse, or better then any mentioned above. 10.80@123. Watching with interest on this post.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Which Intake RPM Air Gap Or Super Victor. [Re: ChrgrCuda] #1587892
03/08/14 12:37 AM
03/08/14 12:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the M-1 Single plane on my 408. Don't know if it's as good, worse, or better then any mentioned above. [Email]10.80@123.[/Email] Watching with interest on this post.
I'm running a Indy single plane on my 416(W-2 engine)
but I'm running a 5000 stall conv on the street..
I havent had much testing yet but the manifold sure
isnt a problem... thats with a 4.10 gear and a 850dp
holley
Re: Which Intake RPM Air Gap Or Super Victor. [Re: MR_P_BODY] #1587893
03/08/14 01:39 AM
03/08/14 01:39 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm going to say it'll have gobs of torque either way. My 408 with the Victor and 4.10 gears pull from anywhere. Heck when it 275s on it if I floored it at 1500 rpms in high gear it would break the tires lose. The only way I'd run a dual plane on a 4" engine would be a truck motor.
Re: Which Intake RPM Air Gap Or Super Victor. [Re: justinp61] #1587894
03/08/14 02:22 AM
03/08/14 02:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It will pull down to a much lower RPM... this is a
street car so its well below the torque curve
Re: Which Intake RPM Air Gap Or Super Victor. [Re: MR_P_BODY] #1587895
03/08/14 06:50 PM
03/08/14 06:50 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine is a street car too, it makes it to the strip a few times a year though.
Re: Which Intake RPM Air Gap Or Super Victor. [Re: dusterjp] #1587896
03/09/14 12:51 AM
03/09/14 12:51 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
My air gap with 0 work done to it went 10's and was nice on the street.
