The "wheel " flex plate .. #1587191
03/03/14 12:07 AM
03/03/14 12:07 AM
iowa
rook440 Offline OP
rook440  Offline OP
iowa
A friend of mine Jim VanZee is wondering if anyone has ran JW's wheel solid flexplate ...he is running a 500 inch RB with a 727 and the bolts (8) keep loosing up ...does anybody run one of these and if they are any good or what would you recommend ...???
Re: The "wheel " flex plate .. [Re: rook440] #1587192
03/03/14 12:16 AM
03/03/14 12:16 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've run the B&M flexplate with the pie cut for external balance so you don't have to run weights on the converter.
Works great!
Re: The "wheel " flex plate .. [Re: GY3] #1587193
03/03/14 04:05 AM
03/03/14 04:05 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
I've run two of them behind a blown 557 KB in my altered, ran the first one til the cert ran out,on my second year on the second one. Can't complain about them.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: The "wheel " flex plate .. [Re: rook440] #1587194
03/03/14 11:11 AM
03/03/14 11:11 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
If the bolts keep loosening, check your timing. Too much or too little will cause that, it has nothing to do with the flex plate. Also, check your bell-housing alignment, if timing doesn't do it.
Re: The "wheel " flex plate .. [Re: rook440] #1587195
03/03/14 11:45 AM
03/03/14 11:45 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I would not question the FP ... I would look at any severe VIBRATION ISSUES or a faulty converter ... like bad threads on the bolt pads OR the lack of a good lock-tite ON those bolts.
Re: The "wheel " flex plate .. [Re: dOoC] #1587196
03/03/14 02:02 PM
03/03/14 02:02 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I have seen this as well, the plate is high strenghth steel so the bolts come loose once in a while. We saftey wired mine. My
Re: The "wheel " flex plate .. [Re: Biginchmopar] #1587197
03/03/14 02:12 PM
03/03/14 02:12 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The wheel is one of the best you can get,as for the flex plate bolts coming loose I always use Lock-tite blue or red which ever I have on mine.When I want to take them out tap them with a hammer and remove them with the impact wrench.Take a wire bush on the grinder or drill and clean the treads and run a tap through the holes to clean the tread and you are ready to reassemble them again.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: The "wheel " flex plate .. [Re: Biginchmopar] #1587198
03/03/14 03:23 PM
03/03/14 03:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine never loosen up and I use red loctite and star washers..........
Re: The "wheel " flex plate .. [Re: Thumperdart] #1587199
03/03/14 08:34 PM
03/03/14 08:34 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I have never, ever, needed or used locktite on converter bolts. Every time I had them loosen up, it's been something else causing it.
