Re: The "wheel " flex plate ..
[Re: rook440]
#1587194
03/03/14 11:11 AM
03/03/14 11:11 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
A friend of mine Jim VanZee is wondering if anyone has ran JW's wheel solid flexplate ...he is running a 500 inch RB with a 727 and the bolts (8) keep loosing up ...does anybody run one of these and if they are any good or what would you recommend ...???
If the bolts keep loosening, check your timing. Too much or too little will cause that, it has nothing to do with the flex plate. Also, check your bell-housing alignment, if timing doesn't do it.
[Re: rook440]
#1587195
03/03/14 11:45 AM
03/03/14 11:45 AM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
I would not question the FP ... I would look at any severe VIBRATION ISSUES or a faulty converter ... like bad threads on the bolt pads OR the lack of a good lock-tite ON those bolts.
[Re: Biginchmopar]
#1587197
03/03/14 02:12 PM
03/03/14 02:12 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
The wheel is one of the best you can get,as for the flex plate bolts coming loose I always use Lock-tite blue or red which ever I have on mine.When I want to take them out tap them with a hammer and remove them with the impact wrench.Take a wire bush on the grinder or drill and clean the treads and run a tap through the holes to clean the tread and you are ready to reassemble them again.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
