Page 2 of 3 1 2 3
Re: Anti roll bars who has them? [Re: 1967dartgt] #1587085
03/03/14 02:02 AM
03/03/14 02:02 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Wafflebatter and I put one in the Arrow last winter. With the car being so narrow it really helped.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Anti roll bars who has them? [Re: Eric] #1587086
03/03/14 02:06 AM
03/03/14 02:06 AM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Ladder car or four link?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Anti roll bars who has them? [Re: 1967dartgt] #1587087
03/03/14 02:29 AM
03/03/14 02:29 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I might put one on the 70 but the 67 launches straight enough.
Re: Anti roll bars who has them? [Re: 1967dartgt] #1587088
03/03/14 02:40 AM
03/03/14 02:40 AM
gregsdart Offline
gregsdart  Offline
No anti-roll bar four link set-up.
Generally speaking ladder bars don't need them, but four links like them. I wonder how much or any the car would pick up with one?
no anti roll in this picture
anti roll in the avatar pic
ladderbars. I figure I gained .02 in the 60 ft.
Re: Anti roll bars who has them? [Re: gregsdart] #1587089
03/03/14 10:04 AM
03/03/14 10:04 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
My input here is this... I've watched enough crashes to see that alot of cars would benefit from anti roll bars. It seems the first thing guys do when setting up thier cars is remove the front sway bar. This is probably the worst thing you could do to a car that is traveling at the speeds we see. The problem gets compounded when you throw a ladder bar into the mix. A car with a ladder bar and no front bar usually will hit the wall. Stiffening the back without doing the same to the front may be fine when the car is in a straight line, but it can and does turn into meyhem when the car gets loose at speed. My advice is if you are adding a rear sway device, do the same to the front. This applies to "stock" front suspensions, not low/ strut cars.
As far as what rear bars do for launch, I added one after a few years of going without on a 4 link. It calmed the car down on the launch to a much more manageable line down the track, although my best 60 ft was without the bar (1.28 vs 1.29 with) The car drove down the track like a caddilac. I wouldn't build a stockish door car without one
Re: Anti roll bars who has them? [Re: TRENDZ] #1587090
03/03/14 12:45 PM
03/03/14 12:45 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I will never run a four link again without one. Our car can be a real handful without it, and with it, just night and day difference.
We had some trouble setting up the four link. We finally got that set-up better, but still had some pretty good roll to the passenger side. It would roll to the passenger side on launch and then the other way on decel to the point your correcting with the steering wheel.
When we put the S&W bar on it, we rescaled the car, set the coil overs level, and adjusted the preload on the sway bar...Car leaves level, and goes thru the traps level. For me, its about safety. We had some aborted runs when the track was marginal, and since doing this, it seems like the car is easier to drive and handle.
I see even the dragsters steer to the right on the launch and have to correct all the way down the track...Do I have to have it to get down the track, No, but I will not do another without it.
Re: Anti roll bars who has them? [Re: 1967dartgt] #1587091
03/03/14 12:47 PM
03/03/14 12:47 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
4 link..
Re: Anti roll bars who has them? [Re: 1967dartgt] #1587092
03/03/14 04:59 PM
03/03/14 04:59 PM
Az
Crizila Offline
Crizila  Offline
Az
I think a lot depends on the type of car you are running and the speeds / ET's you are running at. Short WB, low 10 / 9 second car or faster would benefit. On the other hand, Long WB, 10 second car, leaf spring suspension, might not need them. My car came factory equipped with BIG bars front and rear. For a land yacht, handled great - stayed nice and flat around turns. Removed the front bar first ( running high 11's ) and noticed no handling maladies at the track. Removed the rear bar and went to Cal-Trac springs and traction bars ( running mid 10's and upper 120's ). No change in handling. Probably dropped an easy 60 lbs by removing both bars. Never had the car get way out of shape, even in a big cross wind - probably due to a 117" WB and 3600 lbs.? Low 10's and 130's might a different story if I ever get there without breaking stuff.
Fastest 300
Re: Anti roll bars who has them? [Re: Crizila] #1587093
03/04/14 12:15 AM
03/04/14 12:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't use a ARB. It leaves dead level. The car handles well at speed. Stock rear frame rails with ladder bar. 1.32-1.34 60 ft. Best of 9.25@147 on 10.5's@3340.
Doug
Re: Anti roll bars who has them? [Re: dvw] #1587094
03/04/14 06:58 AM
03/04/14 06:58 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I think some of you are missing the point. you can adjust the car to leave straight and level. the anti-roll allows you to use less adjustment thus maybe gaining a little in 60'
Re: Anti roll bars who has them? [Re: Quicktree] #1587095
03/04/14 11:54 AM
03/04/14 11:54 AM
gregsdart Offline
gregsdart  Offline
With my car it seemed to be the length of the ladderbar, combined with where the front mount was on the neutral line. When in the bottom hole, the ladderbar straddled the neutral line and the body roll was severe. If I moved it up away from the neutral line it calmed down.
A short instant center that straddles the neutral line must allow the left side to rise above it and gain leverage upward due to torque roll from the motor which then forces the right side down below the neutral line, and the forces feed on each other to cause severe body roll. That seems to me why some have very little need, (high torque, two speed, long instant center above the neutral line) while others don't.
I am betting that the gains seen would be related to preload needed without the anti roll, and how much of the available traction a car needs. I can see where a smallblock car with a glide and big tires would not see anything at all in a lot of cases. A nose heavy, bigblock three speed car on the other hand may gain a lot.
Re: Anti roll bars who has them? [Re: dvw] #1587096
03/04/14 11:59 AM
03/04/14 11:59 AM
Hilltown Pa
Hilltown Pa
I don't use a ARB. It leaves dead level. The car handles well at speed. Stock rear frame rails with ladder bar. 1.32-1.34 60 ft. Best of [Email]9.25@147[/Email] on 10.5's@3340.
Doug
Now I go 5 mph less on motor then you and sixty foot the same. Do you think you are leaving et on the table? Does your class allow them?
Re: Anti roll bars who has them? [Re: 1967dartgt] #1587097
03/05/14 12:52 AM
03/05/14 12:52 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I don't have one, but plan on finally putting one in now that we have a track to run at again. Four-link car weighing in at 3550 all-in. Best of a 9.92 @ 135.
Have so much trouble hooking up on marginal track (Irwindale) with radial slicks I don't even bother going there any more.
LOT'S of body roll, but the car drives straight and true when it hooks.
Re: Anti roll bars who has them? [Re: 1967dartgt] #1587098
03/05/14 03:43 PM
03/05/14 03:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Getting ready to put mine in.
It is better to have one fully welded on a big h.p. rather that this style with the aluminum splined arms the splines will strip out. I have seen it happen. We fully welded mine all out of c.m. steel.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Anti roll bars who has them? [Re: 6PKRTSE] #1587099
03/05/14 03:44 PM
03/05/14 03:44 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Another shot of the whole assembly.
Re: Anti roll bars who has them? [Re: G_bob] #1587100
03/05/14 05:17 PM
03/05/14 05:17 PM
Guitar Jones Offline
My car leaves like that too, and I have a bunch of preload in the upper right bar. Goes straight down the track though. I'm going to put one on mine too.
Suggestions for whose bar is better are welcome.
Re: Anti roll bars who has them? [Re: Guitar Jones] #1587101
03/05/14 05:25 PM
03/05/14 05:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the S&W one
Re: Anti roll bars who has them? [Re: G_bob] #1587102
03/05/14 05:28 PM
03/05/14 05:28 PM
gregsdart Offline
gregsdart  Offline
You should see some gains on your car with an anti roll, especially with radial slicks that are being over powered as it is. I had to go to less air to get some hook, and lost the 60 foot after about 25 passes. It went away by .06 to .07 almost instantly. I suspect I should have tried switching the tires side to side, but switched to a bias for safety reasons.
Re: Anti roll bars who has them? [Re: gregsdart] #1587103
03/05/14 05:44 PM
03/05/14 05:44 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Will a anti roll bar help with a cross wind?
Re: Anti roll bars who has them? [Re: Sammy] #1587104
03/05/14 05:52 PM
03/05/14 05:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Note on mine we used oil lite bronze for bushings & drilled tapped for a grease zerk fittings to keep it lubed. It will bind with time if not lubed. This saves from having to take it all back apart to do so each time.
Page 2 of 3 1 2 3
