Re: Anti roll bars who has them?
[Re: Guitar Jones]
#1587105
03/05/14 07:36 PM
03/05/14 07:36 PM
Quicktree
I don't have one, but plan on finally putting one in now that we have a track to run at again. Four-link car weighing in at 3550 all-in. Best of a 9.92 @ 135. Have so much trouble hooking up on marginal track (Irwindale) with radial slicks I don't even bother going there any more. LOT'S of body roll, but the car drives straight and true when it hooks.
My car leaves like that too, and I have a bunch of preload in the upper right bar. Goes straight down the track though. I'm going to put one on mine too.
Suggestions for whose bar is better are welcome.
ART makes a good one only get the heavy duty ones, the aluminum ones will cause you trouble.
[Re: Sammy]
#1587106
03/05/14 07:41 PM
03/05/14 07:41 PM
Quicktree
Will a anti roll bar help with a cross wind?
anything that helps stabilize the car should help
[Re: 1967dartgt]
#1587107
03/05/14 08:12 PM
03/05/14 08:12 PM
Posts: 9,848 MI, usa
dvw
MI, usa
I don't use a ARB. It leaves dead level. The car handles well at speed. Stock rear frame rails with ladder bar. 1.32-1.34 60 ft. Best of [Email]9.25@147[/Email] on 10.5's@3340. Doug
Now I go 5 mph less on motor then you and sixty foot the same. Do you think you are leaving et on the table? Does your class allow them?
You bet I'm leaving some on the table. But I don't think it's suspension. The car dead hooks. It would hook in a mud puddle. I have the entire suspension very tight, front and rear. Lack of low end power for what ever reason. In order, 4.10, converter to tight, huge plenum, box stock Eddy carbs. Car was brand new last year. Spent plenty of time dialing it for index and being consistent. Now I'll be on to the next step. It should go mid to high 1.20, 5.70? in the 1/8, 9.0? Maybe not either but I'll defiantly be chasing it. Doug
