Re: Need to slow down 9.8 to 10. something
[Re: challenged448]
#1585626
02/28/14 09:29 PM
02/28/14 09:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
For a cheap way to slow down (from 8.90s to 10.0) I made a mech throttle stop but sliding the throttle cable will work also.. but I wanted to run 2 classes so I made the stop which I could put on and take off in less than a minute... plus lower the launch RPM as well as the shift RPM... if you HAVE a smaller carb that works also.. it takes a lot of timing to slow them much
[Re: slantzilla]
#1585630
03/01/14 11:31 AM
03/01/14 11:31 AM
Posts: 4,989 new jersey usa
11secdart
new jersey usa
Moroso makes a throttle stop which is really a bolt and bracket that bolts to the rear carb bolt. I have been using a modified one for years to slow my mid 10 second car down to 11.50s and it works great. A word of advice : the original design of the bracket only uses one bolt to hold it and it can move. I bought a Jegs throttle cable bracket and drilled an additional hole in the throttle stop bracket so now there are two bolts holding it and it can`t move.
[Re: 11secdart]
#1585631
03/01/14 03:37 PM
03/01/14 03:37 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Just disconnect the secondaries, that should do it.
[Re: Guitar Jones]
#1585632
03/01/14 04:12 PM
03/01/14 04:12 PM
Posts: 1,178 Indy
FlyFish
Indy
Disconnecting the secondaries would work, pull a few degrees of timing would work, shift early would work, restrictive air cleaner would work..... FWIW, I successfully slowed my car from 10.7's to 12.0 last year using all of the stuff listed above...plus I launched the car in second gear.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
