Need to slow down 9.8 to 10. something #1585615
02/28/14 06:06 PM
02/28/14 06:06 PM
michigan
challenged448 Offline OP
michigan
do not want the expense etc of running 9s looking for cheap if possible to slow it down a few tenths
Its a 67 barracuda 540 pump gas 727 latter bar coil over
1.37 60 9.86 135.7
Re: Need to slow down 9.8 to 10. something [Re: challenged448] #1585616
02/28/14 06:12 PM
02/28/14 06:12 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Don't open the butterfly's as much.
I got from hi 5's to 6.50 for index racing.
Re: Need to slow down 9.8 to 10. something [Re: FastmOp] #1585617
02/28/14 06:17 PM
02/28/14 06:17 PM
michigan
michigan
do i need a throttle stop or can i get away just adjusting the throttle cable
Re: Need to slow down 9.8 to 10. something [Re: challenged448] #1585618
02/28/14 06:29 PM
02/28/14 06:29 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
slack off the accelerator linkage so you don't get WOT & if you need more retard the timing.
Re: Need to slow down 9.8 to 10. something [Re: rebel] #1585619
02/28/14 07:21 PM
02/28/14 07:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I used a bracket with a bolt that I Screw in and out for adjustment.
What carb u running? Dominators are easy'r to fab something up.
I'm EFI so I didn't have much in the way lol
Re: Need to slow down 9.8 to 10. something [Re: FastmOp] #1585620
02/28/14 07:31 PM
02/28/14 07:31 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Add 200# of ballast
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Need to slow down 9.8 to 10. something [Re: FastmOp] #1585621
02/28/14 07:50 PM
02/28/14 07:50 PM
michigan
michigan
king demon
Re: Need to slow down 9.8 to 10. something [Re: challenged448] #1585622
02/28/14 08:13 PM
02/28/14 08:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
king demon
In my opinion this is why you`re 2-3 slower than you already should be. No disrespect but how much does it weigh?
Re: Need to slow down 9.8 to 10. something [Re: Thumperdart] #1585623
02/28/14 08:51 PM
02/28/14 08:51 PM
michigan
michigan
3400 approx never weighed probably has more but they were not happy with the 9.8 not much reason to try to improve
Re: Need to slow down 9.8 to 10. something [Re: challenged448] #1585624
02/28/14 08:53 PM
02/28/14 08:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Figured it would be lighter I guess..............Can`t help you as much as these guys cos I`m always trying to go FASTER!!!!!!!!!!!!!!!
Re: Need to slow down 9.8 to 10. something [Re: Thumperdart] #1585625
02/28/14 09:02 PM
02/28/14 09:02 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use a willys plate on my 10.oh index truck
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Need to slow down 9.8 to 10. something [Re: challenged448] #1585626
02/28/14 09:29 PM
02/28/14 09:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For a cheap way to slow down (from 8.90s to 10.0) I
made a mech throttle stop but sliding the throttle cable
will work also.. but I wanted to run 2 classes so I
made the stop which I could put on and take off in less
than a minute... plus lower the launch RPM as well as
the shift RPM... if you HAVE a smaller carb that works
also.. it takes a lot of timing to slow them much
Re: Need to slow down 9.8 to 10. something [Re: MR_P_BODY] #1585627
02/28/14 10:38 PM
02/28/14 10:38 PM
michigan
michigan
Thanks for the ideas looks easy to make and would probably be more consistent than just adjusting the cable
Re: Need to slow down 9.8 to 10. something [Re: challenged448] #1585628
03/01/14 06:36 AM
03/01/14 06:36 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Have me drive it. That ought to slow it down at least .4.
Re: Need to slow down 9.8 to 10. something [Re: slantzilla] #1585629
03/01/14 11:31 AM
03/01/14 11:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've used a bolt in several cars with good results to run Index. How close the bolt is placed to the carb shaft pivot point will make a large difference in the amount of bolt length necessary to slow it down. I used to slow a 10 teen car down to 11.0. Same carb's on my 9.25 car trying to hit 9.50 took a WAY longer bolt.
Doug
Re: Need to slow down 9.8 to 10. something [Re: slantzilla] #1585630
03/01/14 11:31 AM
03/01/14 11:31 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Moroso makes a throttle stop which is really a bolt and bracket that bolts to the rear carb bolt. I have been using a modified one for years to slow my mid 10 second car down to 11.50s and it works great. A word of advice : the original design of the bracket only uses one bolt to hold it and it can move. I bought a Jegs throttle cable bracket and drilled an additional hole in the throttle stop bracket so now there are two bolts holding it and it can`t move.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Need to slow down 9.8 to 10. something [Re: 11secdart] #1585631
03/01/14 03:37 PM
03/01/14 03:37 PM
Guitar Jones Offline
Just disconnect the secondaries, that should do it.
Re: Need to slow down 9.8 to 10. something [Re: Guitar Jones] #1585632
03/01/14 04:12 PM
03/01/14 04:12 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Disconnecting the secondaries would work, pull a few degrees of timing would work, shift early would work, restrictive air cleaner would work.....
FWIW, I successfully slowed my car from 10.7's to 12.0 last year using all of the stuff listed above...plus I launched the car in second gear.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Need to slow down 9.8 to 10. something [Re: FlyFish] #1585633
03/01/14 04:17 PM
03/01/14 04:17 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Re: Need to slow down 9.8 to 10. something [Re: FlyFish] #1585634
03/01/14 04:27 PM
03/01/14 04:27 PM
michigan
michigan
I like the idea a bracket and bolt want to run as close to 10.0 as i can. i tried taking 6 degrees of timing out ran 9.93 tried starting in 2nd at a 1/8 mile track slowed 2 hundreds and did not pick the front wheels much i like pulling the wheels up still gives me a thrill. need new tires so it should pick some. wondering if 29.5 11.5 will fit 28 11.5 have some room but it is close to the quarter.
