performer rpm clean up #1585087
02/27/14 05:49 PM
02/27/14 05:49 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
I just noticed I'm getting some rust discoloration on my intake manifold. Any suggestions to clean it up without removing it?
Re: performer rpm clean up [Re: kbcuda] #1585088
02/27/14 05:53 PM
02/27/14 05:53 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
mag wheel cleaner for open pore aluminimum..
I am truckless..
Re: performer rpm clean up [Re: kbcuda] #1585089
02/27/14 06:13 PM
02/27/14 06:13 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Rust??
If you do have rust stains I'd try CLR or Lime-a-way.
Re: performer rpm clean up [Re: roadhazard] #1585090
02/27/14 06:28 PM
02/27/14 06:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rust??
Not on aluminum I wouldn't. Now how aluminum got rust ion it, I dunno.
Don't be the exception.
Re: performer rpm clean up [Re: Supercuda] #1585091
02/27/14 06:55 PM
02/27/14 06:55 PM
scratchnfotraction Offline
Rust??
no anti freeze and a leaky hose I would think?
Re: performer rpm clean up [Re: kbcuda] #1585092
02/28/14 05:35 AM
02/28/14 05:35 AM
Cab_Burge Online work
Cab_Burge  Online Work
Are you sure it is not gas dripping or over flowing when hot? I use the Eagle brand of cast aluminum wheel cleaner, spray it on for 20 to 30 seconds and wash it off very thoroughly I've only had one intake take two doses of that stuff to get them spotless
Re: performer rpm clean up [Re: scratchnfotraction] #1585093
02/28/14 11:27 PM
02/28/14 11:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rust??
I see where you are going there, rusty water staining the intake. Probably.
Re: performer rpm clean up [Re: Supercuda] #1585094
03/01/14 12:28 AM
03/01/14 12:28 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Rust??
Why would one not try a product like CLR on aliminimuimum
Re: performer rpm clean up [Re: kbcuda] #1585095
03/01/14 02:34 AM
03/01/14 02:34 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I've found that wd40 does a fantastic job on our old Corvette's Edelbrock intake manifold that has their so called chrome like "durabrite" finish. Might be worth a shot on a plain aluminum one. Soda blasting or very mild other blasting media works very well,,,but of course normally requires removal of unit.
Re: performer rpm clean up [Re: roadhazard] #1585096
03/01/14 09:17 AM
03/01/14 09:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
CLR uses hydroflouric acid, nasty stuff and it will change the appearance of the aluminum.
Re: performer rpm clean up [Re: Supercuda] #1585097
03/01/14 10:40 AM
03/01/14 10:40 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
CLR uses hydroflouric acid,....
HF, I don't think so.
Re: performer rpm clean up [Re: BSB67] #1585098
03/01/14 11:56 AM
03/01/14 11:56 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
No HF in CLR. I don't think it's even in wheel cleaner anymore. Very scary stuff.
Old, tired, and sometimes broke down. Me, not my car...
Re: performer rpm clean up [Re: Shoozy] #1585099
03/01/14 12:25 PM
03/01/14 12:25 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
How about some cheapO spray-on oven cleaner ?
Re: performer rpm clean up [Re: dOc !] #1585100
03/01/14 01:01 PM
03/01/14 01:01 PM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
Maybe but would probably leave it too white.
Re: performer rpm clean up [Re: Shoozy] #1585101
03/01/14 01:20 PM
03/01/14 01:20 PM
dogdays Offline
dogdays  Offline
Cheapo oven cleaner is mostly lye, which eats aluminum. Not the bright choice.
Mag wheel cleaner, which is meant for aluminum wheels, is a better choice. Still, test it on the bottom first to see what it does.
R.
Re: performer rpm clean up [Re: BSB67] #1585102
03/01/14 02:40 PM
03/01/14 02:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looks like someone changed the formula, you are right no more HF, not in Lime Away anymore either.
Re: performer rpm clean up [Re: Supercuda] #1585103
03/01/14 03:04 PM
03/01/14 03:04 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'm surprised HF was ever in household products. Get it on you and it will leach the calcium out of your bones. Very nasty stuff. I delt with it in very concentrated form at my last job. We had a very strict handling program and our own emergency response unit that trained weekly incase of a spill or contamination problem.
**Photobucket sucks**
Re: performer rpm clean up [Re: 70Cuda383] #1585104
03/01/14 04:15 PM
03/01/14 04:15 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I agree. I don't spend my time following cleaner formulations, but it is hard to believe that HF would have ever been in any household cleaners.
Now CLR use to have phosphoric acid in it. It is unfortunate that it is gone from the formulation, as there really is no good reason for its removal (other than some EPA stuff most likely). I believe that phosphoric acid is the cleaning/oxidation removal agent of choice for aluminum.
