Page 1 of 3 1 2 3
Motor oil in trans #158501
11/28/08 05:00 PM
11/28/08 05:00 PM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
I just bought a 727 from someone on another board. When I dropped the pan for inspection. I was greeted by dirty motor oil. That don't bother me (much). As I plan on putting a B&M Transkit in it. So my question is. Do you think that the oil could have damaged anything such as the valve body?
Re: Motor oil in trans [Re: tscuda] #158502
11/28/08 05:09 PM
11/28/08 05:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It will need a rebuild but the valve body won't be hurt by oil. A good cleaning and your good to go.
Re: Motor oil in trans [Re: stumpy] #158503
11/28/08 05:19 PM
11/28/08 05:19 PM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
I was thinking because it would have had a higher pressure it could have damaged the springs or valves in it.
Re: Motor oil in trans [Re: tscuda] #158504
11/28/08 05:32 PM
11/28/08 05:32 PM
I remember Marvin the mad(727) scientist from Chrysler Power years ago advocated adding motor oil to the trans for it's improved lubrication qualities even going as far as using all motor oil I have added a qt here & there & no problems mainly because I was out of trans fluid & going by him way back saying that it was Ok.
Re: Motor oil in trans [Re: RapidRobert] #158505
11/28/08 05:37 PM
11/28/08 05:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I personally think if it motor oil was to be used in a transmission the mfg would have put it in.Would you put transmission fluid in a motor? Also,anything you add to anything dilutes the original viscosity.
Re: Motor oil in trans [Re: RapidRobert] #158506
11/28/08 05:38 PM
11/28/08 05:38 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
marv booth is his name, i think he recommended adding a quart of 30 weight and said even 100% wouldnt hurt it. i have also added motor oil over the years with no ill effects.
Re: Motor oil in trans [Re: forphorty] #158507
11/28/08 05:49 PM
11/28/08 05:49 PM
It does sound totally ludicrous which is why I had to try it 30 wt would for sure be higher viscosity than atf & if it'd be better(for lube & function) I'd also think Ma would have tried it & used it if it worked better so I dont know...
Re: Motor oil in trans [Re: 62maxwgn] #158508
11/28/08 06:03 PM
11/28/08 06:03 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Yes I will and have, cleans out a nasty set of lifters in a jiffy. Heard of the motor oil in a trans but never tried it. Are you sure thats what it is or just some burnt black tranny fluid?
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Motor oil in trans [Re: 70dart360] #158509
11/28/08 06:18 PM
11/28/08 06:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Might clean out your lifters but I bet it will play h#ll on your bearings.
Re: Motor oil in trans [Re: 62maxwgn] #158510
11/28/08 06:27 PM
11/28/08 06:27 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
People have been doing that for years.
Automatic trans fluid is essentially a high detergent low viscosity (thin) oil.
As long as you don't run the engine hard while the auto trans fluid is in the oil, it's really not much different than having an engine cleaner added to the oil. Either way you don't leave it in there for an extended period.
Re: Motor oil in trans [Re: SNK-EYZ] #158511
11/28/08 07:04 PM
11/28/08 07:04 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
My old shop teacher once told us that if you were to rate transmission fluid using the engine oil viscosity scale, it would be equivalent to a 7w14 motor oil. There are a number of friction modifiers blended into transmission fluid that engine oil does not have so I would be leary of using a full load of engine oil in the trans. Maybe a pint or two for topping up in an emergency but not a complete fill. Can't say if the lack of those modifiers would make the trans more likely to slip or grab, but if this really was engine oil, I would suggest pulling it down and have a look while it's out of the vehicle.
Re: Motor oil in trans [Re: tscuda] #158512
11/28/08 07:15 PM
11/28/08 07:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When the 727 was new and transmission fluid wasn't as sophisticated as it is now many racers ran straight motor oil in the 727, either 10-30 or straight 30 weight.
Re: Motor oil in trans [Re: PC-CHARGER] #158513
11/28/08 07:19 PM
11/28/08 07:19 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
One of my best friends has been a trans man a long time,and has been to many a class. At some of the class's they stated that when putting a valve body and other parts to use 30 wt and gear oil mixed 50-50 as an assembly lube
Re: Motor oil in trans [Re: tscuda] #158514
11/28/08 07:29 PM
11/28/08 07:29 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
motor oil in a transmission ?
NO WAY !
Re: Motor oil in trans [Re: ohiodemon] #158515
11/28/08 07:53 PM
11/28/08 07:53 PM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Was in the Air Force for 20 years, as a Vehicle Mechanic. Most of the larger trucks that had Allison transmissions in them, used 10 Wt (Hydraulic oil). Never had any major failure that I can remember because of the fluid. I know it's not engine oil, but it's along the same lines with different characteristics.
A True Hybrid: Burns Gas AND Rubber!
Re: Motor oil in trans [Re: RapidRobert] #158516
11/28/08 10:17 PM
11/28/08 10:17 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
I have dont this also, I drove 275K miles in my old chevy Z24, and towed a boat during most of its life..
but if yopu trans has black oil in it, it maybe burnt trans fluid..
Re: Motor oil in trans [Re: Dakota_Don] #158517
11/29/08 12:40 AM
11/29/08 12:40 AM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
I'm positive it's motor oil. To thick to be atf. And smells different. I didn't have time today to pull out the valve body. But in the morning I plan to take it out and hose the inside down with brake cleaner. If it's burnt atf I should see some nice pretty blue metal in there.
I was thinking when I seen that that it might have been done to solve a problem. Like how they used to add sawdust to the atf.
Re: Motor oil in trans [Re: tscuda] #158518
11/29/08 01:37 AM
11/29/08 01:37 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
We usually add a qt of 30w non-detergent oil to type F fluid in our trans. Have also used hydraulic oil with some success. Tranny fluid is a poor lubricant and the motor oil helps lube the bushings.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Motor oil in trans [Re: Evil Spirit] #158519
11/29/08 01:50 AM
11/29/08 01:50 AM
Now that you mention it that was the reasoning behind mad marvin booths decision to use motor oil in there.
Re: Motor oil in trans [Re: Evil Spirit] #158520
11/29/08 09:55 AM
11/29/08 09:55 AM
Bellville, Mi.
tscuda Offline OP
tscuda  Offline OP
Bellville, Mi.
I would think that too. But why would the factory switch from 90 weight to atf in the manaual trans.
Page 1 of 3 1 2 3
