Re: Motor oil in trans
[Re: tscuda]
#158504
11/28/08 05:32 PM
11/28/08 05:32 PM
RapidRobert
I remember Marvin the mad(727) scientist from Chrysler Power years ago advocated adding motor oil to the trans for it's improved lubrication qualities even going as far as using all motor oil I have added a qt here & there & no problems mainly because I was out of trans fluid & going by him way back saying that it was Ok.
[Re: forphorty]
#158507
11/28/08 05:49 PM
11/28/08 05:49 PM
RapidRobert
It does sound totally ludicrous which is why I had to try it 30 wt would for sure be higher viscosity than atf & if it'd be better(for lube & function) I'd also think Ma would have tried it & used it if it worked better so I dont know...
[Re: 70dart360]
#158509
11/28/08 06:18 PM
11/28/08 06:18 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Would you put transmission fluid in a motor?
Yes I will and have, cleans out a nasty set of lifters in a jiffy. Heard of the motor oil in a trans but never tried it. Are you sure thats what it is or just some burnt black tranny fluid?
Might clean out your lifters but I bet it will play h#ll on your bearings.
[Re: tscuda]
#158512
11/28/08 07:15 PM
11/28/08 07:15 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When the 727 was new and transmission fluid wasn't as sophisticated as it is now many racers ran straight motor oil in the 727, either 10-30 or straight 30 weight.
[Re: ohiodemon]
#158515
11/28/08 07:53 PM
11/28/08 07:53 PM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
Was in the Air Force for 20 years, as a Vehicle Mechanic. Most of the larger trucks that had Allison transmissions in them, used 10 Wt (Hydraulic oil). Never had any major failure that I can remember because of the fluid. I know it's not engine oil, but it's along the same lines with different characteristics.
A True Hybrid: Burns Gas AND Rubber!
[Re: RapidRobert]
#158516
11/28/08 10:17 PM
11/28/08 10:17 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
I have dont this also, I drove 275K miles in my old chevy Z24, and towed a boat during most of its life..
but if yopu trans has black oil in it, it maybe burnt trans fluid..
[Re: Evil Spirit]
#158520
11/29/08 09:55 AM
11/29/08 09:55 AM
Posts: 220 Bellville, Mi.
tscuda
Bellville, Mi.
Tranny fluid is a poor lubricant
I would think that too. But why would the factory switch from 90 weight to atf in the manaual trans.
