Brushed Trim Ring Question #1584477
02/26/14 10:14 AM
02/26/14 10:14 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
My 1970 Duster 340 has Rallye 14 inch wheels with brushed trim rings. I would like to run 15 inch Rallye wheels on the back for a more aggressive stance. Does anybody make a 15 inch trim ring that has a close appearance to the 14 inch factory ring?
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Brushed Trim Ring Question [Re: FJR doc] #1584478
02/26/14 10:33 AM
02/26/14 10:33 AM
Pretty sure the 15" trim rings were all polished and not brushed.
Re: Brushed Trim Ring Question [Re: ] #1584479
02/26/14 11:07 AM
02/26/14 11:07 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I like the look of the brushed rings. If that's the case, I suppose I could try to duplicate the finish with fine sandpaper or some other abrasive.
Kevin
Re: Brushed Trim Ring Question [Re: FJR doc] #1584480
02/26/14 11:42 AM
02/26/14 11:42 AM
SE Pa.
LimeliteAero Offline
SE Pa.
It seems I stick my foot in my mouth too often, but here goes.
15 trim rings were brushed in 71.
Re: Brushed Trim Ring Question [Re: LimeliteAero] #1584481
02/26/14 12:13 PM
02/26/14 12:13 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Take your foot back out of your mouth. They were brushed for 71. To the OP, nobody makes the correct brushed ring. The outer lip is polished, so like you said the only thing you can do is sand it. What I'm going to do is tape off the lip, and put the ring on an old wheel mounted on the rear axle, then with around 400 sandpaper spin the wheel and sand the ring. The ring that are brushed look like it was done with 80 grit, just trash.
Re: Brushed Trim Ring Question [Re: 71birdJ68] #1584482
02/26/14 12:17 PM
02/26/14 12:17 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
400 may be a bit harsh. I would try red scotch brite first. If that didnt work I would try some 600 wet.
Re: Brushed Trim Ring Question [Re: AdamR] #1584483
02/26/14 12:27 PM
02/26/14 12:27 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Which polished 15 inch trim ring has the closest profile and best fit to an original?
Kevin
Re: Brushed Trim Ring Question [Re: AdamR] #1584484
02/26/14 12:40 PM
02/26/14 12:40 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i thought red scotch brite was 400?
Re: Brushed Trim Ring Question [Re: FJR doc] #1584485
02/26/14 03:49 PM
02/26/14 03:49 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Of the few aftermarket polished rings I have seen the ones from Specialty Wheels looked the best to me.
Re: Brushed Trim Ring Question [Re: FJR doc] #1584486
02/26/14 03:49 PM
02/26/14 03:49 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Specialty ring on the left. On the right another aftermarket ring I was considering due to being less money.
Re: Brushed Trim Ring Question [Re: moparfan53] #1584487
02/27/14 07:14 PM
02/27/14 07:14 PM
Phoenix, AZ
MCTPhoenix Offline
MCTPhoenix  Offline
Phoenix, AZ
I went thru this a few months ago after ordering 15x7 rallies from Summit. I tried the polished and brushed rings and sent them back. I even tried an expensive set from year one and sent them back. The closest to original I found in terms of the fit and finish on the lip came from a place called LMC Truck
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=107 See 38-3777 for the set of four @ $89
Re: Brushed Trim Ring Question [Re: MCTPhoenix] #1584488
02/27/14 10:07 PM
02/27/14 10:07 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I got a set of brushed 15" rings from Summit Racing...$25 each I believe...
1MYTGTX
Re: Brushed Trim Ring Question [Re: 1MYTGTX] #1584489
02/27/14 10:08 PM
02/27/14 10:08 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
These replaced the polished rings I originally got from Specialty Wheels along with he 15" Road Wheels
1MYTGTX
