2005 dakota 4/4 problem
#1584371
02/25/14 10:09 PM
02/25/14 10:09 PM
Posts: 8,240 fredericksburg,va
cudaman1969
fredericksburg,va
I need a little info before doing this myself or taking to dealer. The Dakota will jump in 4 low or 4 high,without turning the knob, then jump back all on its own, the switch will still work if turned to either. After another escapade last nite, drove home in 4 low (till the driveway)then normal, sitting in park touched the brake pedal, right back in 4 low. With the key off and out i can still hear it trying to move in and out. ANY IDEAS, HELP
Re: 2005 dakota 4/4 problem
[Re: cudaman1969]
#1584372
02/26/14 03:49 PM
02/26/14 03:49 PM
Posts: 1,377 Ohio
Todd
Ohio
Drive though any deep water lately? Shift motor on T-case could be full of water making is have a mind of its own. Faulty switch, Integrated Power Module to list other possible causes. Getting the DTC's read at the dealer should be your next step before something gets damaged.
[Re: Todd]
#1584373
02/26/14 06:02 PM
02/26/14 06:02 PM
cudaman1969
fredericksburg,va
Thanks for reply, it has not been in any water. Another question, is the shift motor hot wired and cabin switch a ground or the hot wire goes throughout the cabin switch to shift motor?
[Re: cudaman1969]
#1584376
02/26/14 11:21 PM
02/26/14 11:21 PM
Posts: 1,377 Ohio
Todd
Ohio
Not all dealers are the same. We have a standard fee for diagnostic scan and its competitive to most all the independent garages in the area. A lot of people assume its gonna be expensive. So don't get out the vasaline yet...until you have to buy the parts Lol
[Re: Todd]
#1584377
02/27/14 02:30 AM
02/27/14 02:30 AM
cudaman1969
fredericksburg,va
I need to be in Ohio. lol Like your Savoy, I'm redoing mine now, cm cage and a 540 Hemi. Bought my first in 68 and this is my third, bought in 92.
