Re: Tail Light Lens (Polish?)
[Re: filmsurgeon]
#1584261
02/25/14 06:09 PM
02/25/14 06:09 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Sand it out. Did you try plastic cleaner. Meguiers sold a cleaner and a polish. The cleaner is what cut the scratches. Try some toothpaste, since it's handy and basically free. Wenol works good too. If that all doesn't work, you need to sand it out. 1200, 800, 600 grit wet sanding on a small block to keep it level. Good post on this: https://board.moparts.org/ubbthreads/show...rue#Post7714490
[Re: AAR#2]
#1584263
02/25/14 10:39 PM
02/25/14 10:39 PM
Posts: 12,158 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Try the polish route first. If polish doesn't work, glass bead it for texture and then clear coat it. You should use gun clear, the 2 part kind.
I have done this a lot of times to tail lights and I do it to late model dull headlights on a regular basis.
Master, again and still
[Re: autoxcuda]
#1584264
02/25/14 11:16 PM
02/25/14 11:16 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
Sand it out.
Good post on this:
if that doesn't work then try "headlight lens restore", comes in kit form.
[Re: srt]
#1584266
02/26/14 11:58 AM
02/26/14 11:58 AM
Posts: 6,584 SE Pa.
LimeliteAero
SE Pa.
Maguires sells a headlight polishing kit that comes with two different abrasive discs (progressive) and two bottles of liquid, one for cleaning/maintaining and one for polishing along with a wool pad to attach to a drill. http://www.meguiars.com/en/automotive/products/g1900-headlight-restoration-kit/ I used this on all of my lenses! I picked up an NOS (RED) side marker that was less than perfect and this made it sparkle!
[Re: srt]
#1584267
02/26/14 01:26 PM
02/26/14 01:26 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
toothpaste not kidding try regular crest and a damp terry rag and a firm circular motion. if that does not get it go with a more agressive pearl drops or a tartar removal type and finish with the regular stuff.
I used toothpaste to polish my cloudy headlite covers on my daily driver. Use regular paste, not the gel.
