Re: Glyptal/internal engine painting questions [Re: MR_P_BODY] #1584068
02/27/14 12:50 AM
02/27/14 12:50 AM
dogdays Offline
dogdays  Offline
Also keeps any casting sand from working out of the block.
Glyptal is wonderful stuff, I even have a quart of it, never had an engine that was special enough to put it on!
R.
Re: Glyptal/internal engine painting questions [Re: dogdays] #1584069
02/27/14 01:08 AM
02/27/14 01:08 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
It's not to be used on alcohol. The paint can says so.
Yes, you absolutely should not drink and paint !
On a more serious note, I would hope that ANY fuel I was running would not find its way to any of the places the glyptol is used !!!
Re: Glyptal/internal engine painting questions *DELETED* [Re: Stanton] #1584070
02/27/14 12:16 PM
02/27/14 12:16 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Post deleted by moparts
Re: Glyptal/internal engine painting questions [Re: FastmOp] #1584071
02/27/14 12:55 PM
02/27/14 12:55 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im a fan, I know some think its a waste of time, but the oil drain back is the main reason I did mine. Also keeps the valley cleaner so you can see at a glance if theres something thats not suposed to be there, Roller bearings, flakes of stuff, etc, etc...
Do it right, clean the block properly it should last and last.
Re: Glyptal/internal engine painting questions [Re: Moparnut426] #1584072
03/24/14 04:07 PM
03/24/14 04:07 PM
San Diego, USA
SoCalRacer Offline
SoCalRacer  Offline
San Diego, USA
After several seasons of racing and just now torn down for its third ring/bearing freshen up the paint looks like new with no chips or flaking.
If it ain't broke ... you're not pushing it hard enough.
Re: Glyptal/internal engine painting questions [Re: SoCalRacer] #1584073
03/24/14 07:08 PM
03/24/14 07:08 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
painting an engine internally started in the '60's. back in the day we did it not so much for oil drainback but to seal the casting from silicon/sand and who knows what from breaking loose during thermal cycles. a lot of racers were using green blocks back then. back then there wasn't any thermal cleaning. everything was a hot tank and the iron had a dirty texture/light surface rusting. we also used the rustoleum damp proof red primer in a can and brushed it on to seal everything. this paint had lead in it so it's no longer available.
Re: Glyptal/internal engine painting questions [Re: lewtot184] #1584074
03/24/14 07:56 PM
03/24/14 07:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not only does it seal in any casting residue it also seals the pores to keep the black soot that discolors the oil from being trapped in the pores and contaminating fresh oil after an oil change.
Other than cost/labor, there is no downside to Glyptal or Rustoleum Damp Proof Primer.
