440 build #1583917
02/24/14 10:50 PM
02/24/14 10:50 PM
Suffield, CT
furyman1966 Offline OP
Suffield, CT
Building a 77' 440 for my 66 Fury. Heres the line up so far. Balanced cast crank, 440 source rods, trw flat tops, gasket matched 906 heads, MP 509 cam 114 centerline. 3500 stall, 3.91 rear. Plan on running Edelbrock rpm intake. Few questions:
Carb sugguestion?
Can I run stock rockers/push rods with this cam?
The heads need new valves, should I go 2.14/1.81?
What do you guys think?
THANKS!! Paul
Re: 440 build [Re: furyman1966] #1583918
02/24/14 10:56 PM
02/24/14 10:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Carb sugguestion?
- 950 HP with the small venturies
- You can, but I would not. At least buy new.
- Yes
Re: 440 build [Re: BSB67] #1583919
02/24/14 11:05 PM
02/24/14 11:05 PM
Suffield, CT
Suffield, CT
With the motor came new sealed power rockers/shafts...am I asking for a disaster?
Re: 440 build [Re: furyman1966] #1583920
02/24/14 11:19 PM
02/24/14 11:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
if you're running trw pistons make sure they're the lightweight ones not the heavy 2355s. or run kb237's.
ditch the 509 cam. old tech and a lazy cam for the street. try the lunati voodoo 60304 or 60305. I ran the 60303 with stock rockers and pushrods. they've went to a new part number system for their cams but you can figure it out on their website.
step up to the 440source stealth heads or eddy rpm heads. you'll be able to run more compression and swt your engine up for quench. win win fpr a street car.
Re: 440 build [Re: furyman1966] #1583921
02/24/14 11:22 PM
02/24/14 11:22 PM
Sounds like a fairly hot built. Reading Dulcichs' BB porting articles (highly recommended) iirc you're better off staying with the stock valve sizes with the "early" (915/906) heads unless you are a skilled porter with a flow bench & the "later" 452's (& 346's iirc) are a FAR better choice for larger valves/careful backyard porting. I would use the MP templates on the 906's (std valve sizes) & if using those templates on 2.14/1.81's on the later heads you'd need to cut the templates wider the amount of the valve increase. .030" wider per side (2.14-2.08= .060" & divide that in half) for the intakes for example. there's actually enough room on the template sheet to cut out the originals for 906's then trace em wider on the extra sheet space using the curved edge on each side of the template to go out wider for new patterns. EDIT I would not purchase that cam/pistons if you do not already have them (trw 2355's are very heavy). What was up with the OE rods?
Re: 440 build [Re: RapidRobert] #1583922
02/24/14 11:26 PM
02/24/14 11:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
.509
I am truckless..
Re: 440 build [Re: 340SHORTY] #1583923
02/24/14 11:41 PM
02/24/14 11:41 PM
Suffield, CT
Suffield, CT
Unfortunately 2355's and a 509 I already own...can I make it work?
Re: 440 build [Re: furyman1966] #1583924
02/24/14 11:48 PM
02/24/14 11:48 PM
Yes you can. degree it/check VP clearance/measure SCR
Re: 440 build [Re: BSB67] #1583925
02/24/14 11:56 PM
02/24/14 11:56 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
don't know if it is to big for your combo, but i do have a edelbrock 800 thunder series carb with maybe 200 miles on it,worked awesome on my set-up similiar to yours,decided to put a 6 pak on,otherwise a great carb., but the one thing i didn't like was it actually "looks" small on a 440, but i do also have the street/strip holley dominator intake if you are interested pm me, good luck Darren
Re: 440 build [Re: meepmeep70] #1583926
02/25/14 05:04 AM
02/25/14 05:04 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I would run a real 509 in that combo in a heart beat, but I would not have bought the "revised" 509. You've got a solid set up though, it will run strong if the tune up is right.
You can run stock rockers but you need to measure the push rods and get the correct length pushrods to do it right.
Re: 440 build [Re: GTX MATT] #1583927
02/25/14 08:51 AM
02/25/14 08:51 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
750 Holley for the street 850 at the most even with the 2.14/1.81 valves and stock ports.
Pick yourself up a nice set of Ductile adjustable rockes and your good to go.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: 440 build [Re: BB65Barracuda] #1583928
02/25/14 10:20 AM
02/25/14 10:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm not a huge fan of the 509 for your application. I guess you can advance it some and it wil work better. As for the valve train, yes you can and I don't think you'll have any issues, as long as it's new. As for a carb it depends on what you want to do. If you just want a decent cruiser an 800 thunder would be ok, if you want max performance a Holley HP series would be best. Good luck. I hope you are using headers and a decent exhaust.
Coming soon!!!!
Re: 440 build [Re: Mr.Yuck] #1583929
02/25/14 12:01 PM
02/25/14 12:01 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
I think the default 500hp 440 build up is still in the tech archives. Your pretty much there.
Re: 440 build [Re: bobby66] #1583930
02/25/14 01:52 PM
02/25/14 01:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Without doing the REQUIRED porting putting the larger valves in the 906's is a complete waste of time and money, you gain nothing other than a fresh, unsunk valve seat.
Plus once you pay for that work you could have bought a set of Ebrock heads and have less of a chance of having to mix race gas because your compression will be too high with no quench and those 906's.
Re: 440 build [Re: JohnRR] #1583931
02/25/14 09:30 PM
02/25/14 09:30 PM
Suffield, CT
Suffield, CT
Thanks for all the help guys. This won't be a race car but I want it to run strong. I went back and fourth between the Eddy RPM and Street Dominator, figured since its a heavy car I'd use the RPM...am I loosing noticeable top end power with it? I want it to light up the tires with ease.
Re: 440 build [Re: furyman1966] #1583932
02/25/14 11:18 PM
02/25/14 11:18 PM
All I can add is the SD is very low profile and the RPM is VERY tall. I dont think you'll have a problem lighting em up either way. If hood clearance will allow (a low profile air cleaner can take care of some of that) I'd probably go with the RPM & it is a dual plane square bore flange & the SD is a single plane spread bore flange
Re: 440 build [Re: furyman1966] #1583933
02/26/14 12:29 PM
02/26/14 12:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it's not going to be a race car what you lose in top end power is of little consequence , you want to light up the tires that is torque down low and for that the dual plane wins.
But as mentioned you will have to deal with hood clearance issues with the RPM , to a lesser degree with the SD .
