Re: Shelby Dakota Radiator Question
[Re: moparrush]
#1583912
02/24/14 11:43 PM
02/24/14 11:43 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
i'll shoot some pics in the morning, upper hose on the drivers side, lower on the pass. trans tank on the bottom, with a trans cooler inline. it's the same radiator used in the 4x4 sport with the v-6.
[Re: moparrush]
#1583914
02/25/14 06:06 PM
02/25/14 06:06 PM
Golden-Arm
Sunny South Florida
the rad is 26" wide, 22" tall (from bottom of tank to top of tank) and 2" deep. it has 2 rows. flange mounted on front side, to back of rad support. as i mentioned above, just get a 1989 dakota sport v-6 radiator, unless the "shelby" one is the same price. as far as the fans go, if you have original fans, they mount to the front of the rad support, using the same holes the radiator mounts to. you have to pull the grill and headlight surrounds, and will have to move the center support. the outline of the fan mount should be visible on the radiator support, where it was mounted before.
[Re: moparrush]
#1583916
02/26/14 04:38 AM
02/26/14 04:38 AM
Golden-Arm
Sunny South Florida
yeah, there's a small grommet to keep to from laying right against the support. check the fans before you put it all back together. it sucks to have to pull the front apart, to find out why they dont work, if they dont.
