Page 10 of 12 1 2 8 9 10 11 12
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583661
07/01/14 05:06 PM
07/01/14 05:06 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Here are links to them and instructions:
Moroso Oil Restrictors
Instructions
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583662
07/01/14 05:07 PM
07/01/14 05:07 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Those restrictors have been used in chevys for a long time and are readily available from several sources. I have used them in pushrod oiled mopars before, only needs minor modifications to make the chevy stuff work. http://www.summitracing.com/dom/parts/sum-120120/overview/
Plynouth VIP '67 TT IC EFI
Re: Keith Black Aluminum block ordering experience [Re: jyrki] #1583663
07/01/14 05:36 PM
07/01/14 05:36 PM
NC
440Jim Online work
440Jim  Online Work
NC
It looks like a couple variations are available.
One uses 1/4-18 NPT threads,
the other uses 5/16-18 machine threads.
The pipe thread OD is much larger (about 0.5") compared to the machine thread OD (about 0.3"). So it depends how the block is machined.
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583664
07/01/14 05:43 PM
07/01/14 05:43 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Where are you putting them in at exactly?
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583665
07/01/14 06:02 PM
07/01/14 06:02 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
If they go in at the back of the galley under the bell housing, isn't it a pain the change them out if you need to adjust them?
Greg
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583666
07/01/14 06:17 PM
07/01/14 06:17 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
You are gonna run 440-1 heads. Are you going to use the ports on top at the rear of the block for the oil lines? I have a World / 440-1 for my 540 and after seeing the Indy set-up for oiling the heads (flimsey) I made a pair of AN-4 lines and put pipe plugs under each of them after I opened up the threads and reduced the height of the plugs. In each plug I have 0.060 dia holes. A set of 0.090 plugs are waiting if I need more oil to the heads. They can be changed with the engine bolted to the tranny.
Another way of doing the same thing I think.
Re: Keith Black Aluminum block ordering experience [Re: Airwoofer] #1583667
07/01/14 06:33 PM
07/01/14 06:33 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Push rod oiling.
Original B1's with paired rockers.
Greg
Re: Keith Black Aluminum block ordering experience [Re: Airwoofer] #1583668
07/02/14 11:09 AM
07/02/14 11:09 AM
NC
440Jim Online work
440Jim  Online Work
NC
The KB block has a separate oil gallery going to the main bearings first (priority). The restrictors keep high pressure/flow to the main bearings, while reducing pressure/flow to the lifter galleries (lifters, pushrod oiling to the heads). I don't think the lifter galleries are even drilled on most KB blocks, you have to buy that option (I did for pushrod oiling to the heads).
When my block arrives, I will check; but I believe the restrictors allow full pressure to the ports on the rear/top of the block and only reduce pressure to the lifter galleries.
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583669
07/02/14 12:00 PM
07/02/14 12:00 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
I ordered mine for push rod oiling.
So when you talked to Ken yesterday, did he give you an ETA? Or did he just say that it will be started this week? We will lose a day this week because of the 4th too.
Greg
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583670
07/02/14 02:05 PM
07/02/14 02:05 PM
Tulsa, Ok
Tulsa, Ok
Jim, I can confirm this. The restrictors go in past the main oil passage so they won't impact the ports on the rear/top of the block.
Re: Keith Black Aluminum block ordering experience [Re: WadeMetzinger] #1583671
07/02/14 04:19 PM
07/02/14 04:19 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
If you need to adjust the oil flow, isn't it a pain in the a##?
Greg
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583672
07/02/14 04:31 PM
07/02/14 04:31 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I had my lifter bores bushed and put very small holes in the bushings.
Oil control should not be a problem.
Re: Keith Black Aluminum block ordering experience [Re: 1320Dart] #1583673
07/03/14 01:15 PM
07/03/14 01:15 PM
NC
440Jim Online work
440Jim  Online Work
NC
No delivery date. He said he expected to get the 1st and 2nd machining operations done this week and get the block to the other shop to gun drill the lifter galleries no later then Monday. Then back to his shop for finish machining, including the lifter bores.
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583674
07/03/14 03:44 PM
07/03/14 03:44 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Sounds like its moving along then.
Greg
Re: Keith Black Aluminum block ordering experience [Re: 440Jim] #1583675
07/08/14 11:16 AM
07/08/14 11:16 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
440Jim-
How goes the build?
Greg
Re: Keith Black Aluminum block ordering experience [Re: jyrki] #1583676
07/08/14 11:39 AM
07/08/14 11:39 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
As stated above, been used since the beginning of time in Chevies. Its a simple deal. There ARE several different version of them, so be careful if re-ordering. There are early and late style ( depends on the Chevy block). There are different thread version as well. I would suggest getting some extra o-rings for them, as they do have a tendancy to rip or tear coming in and out. No biggie, just keep some spares on hand.Make sure if this happens, you get your little dental pick and get ALL of the oring out. Some are internal hex drive, others are external hex. Your preference. MAKE SURE you lube up the o-ring before installing, and usually a gentle twisting turning motion to help the oring seat.
RIP Monte Smith
Re: Keith Black Aluminum block ordering experience [Re: CompWedgeEngines] #1583677
07/09/14 02:37 AM
07/09/14 02:37 AM
CALIFORNIA, USA
KB RACING ENG Offline
CALIFORNIA, USA
OK, I thought I would take a little time to send some photos that I just took tonight of Greg's and Jim's blocks. I tried to do this just a little bit ago but the photos caused my post to crash so I will give it another try.
Greg just a final inspection and waiting on our CORE PLUGS from our vendor, they are about two months late but I was told that they shipped today.
Jim, Block is back from gun drill and Tom is just about finished with the sleeves for your Low Deck 440 so it is almost ready for final operations.
I will call both of you with more detailed information tomorrow.
Ken
Not having much luck posting all of the photos so I guess I will have to post one at a time.
Re: Keith Black Aluminum block ordering experience [Re: KB RACING ENG] #1583678
07/09/14 02:39 AM
07/09/14 02:39 AM
CALIFORNIA, USA
CALIFORNIA, USA
Greg 2
Re: Keith Black Aluminum block ordering experience [Re: KB RACING ENG] #1583679
07/09/14 02:40 AM
07/09/14 02:40 AM
CALIFORNIA, USA
CALIFORNIA, USA
Jim 1
Re: Keith Black Aluminum block ordering experience [Re: KB RACING ENG] #1583680
07/09/14 02:41 AM
07/09/14 02:41 AM
CALIFORNIA, USA
CALIFORNIA, USA
Jim 2
