Another high tech tool from my scrap metal bin. #1583034
02/24/14 01:06 AM
02/24/14 01:06 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Magnetic base mount for checking cam / lift.
Fastest 300
Re: Another high tech tool from my scrap metal bin. [Re: Crizila] #1583035
02/24/14 01:48 AM
02/24/14 01:48 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Works for me
Re: Another high tech tool from my scrap metal bin. [Re: rowin4] #1583036
02/24/14 03:47 AM
02/24/14 03:47 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Good idea. Ron
Re: Another high tech tool from my scrap metal bin. [Re: 383man] #1583037
02/24/14 08:45 AM
02/24/14 08:45 AM
Texas
mprhound Offline
mprhound  Offline
Texas
Could you use that to set valve lash or easier with feeler gauges ?
Re: Another high tech tool from my scrap metal bin. [Re: mprhound] #1583038
02/24/14 11:25 AM
02/24/14 11:25 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
great idea,but the real trick is ,how do you keep all the oil from runnin out on the floor?
Re: Another high tech tool from my scrap metal bin. [Re: mprhound] #1583039
02/24/14 12:06 PM
02/24/14 12:06 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Probably easier with feeler gauges - although I have never tried it with a dial indicator ( other than my old P&G valve gaper). Just too much wiggle with the stud style rocker mount. My cam card calls for .012" on both in. & ex. I use a .012 and a .014. .012 won't go in = too tight. .014 goes in = too loose. I just use that set up for checking cam condition / lift. Anything within a .010" - .012" range is acceptable.
Fastest 300
