Took my 68 apart years ago and need some detail pictures of the front head liner mldg attachments above the windshield. I have 4 clips that go into round holes that the moulding screws into. It looks like the outboard holes in the mldg line up with a small square hole. This also is where it covers the A pillar plastic cover. Is there some sort of insert that goes into that square hole that would hold a screw ? Will try to post pics later of it but hoping someone can help
Also, having trouble figuring out if I need sail panels.....If I remember right my car had them...Does anyone have a picture of their head liner installed but before the sail panels ? Just trying to picture how this area goes back together also. It looks like the 'toothed" brackets go all the way to the bottom of the rear window in the sail panel area so that is confusing me.
