68 coronet headliner details #1582778
02/23/14 12:17 PM
02/23/14 12:17 PM
Back In Iowa
belv2vert66 Offline OP
Back In Iowa
Took my 68 apart years ago and need some detail pictures of the front head liner mldg attachments above the windshield. I have 4 clips that go into round holes that the moulding screws into. It looks like the outboard holes in the mldg line up with a small square hole. This also is where it covers the A pillar plastic cover. Is there some sort of insert that goes into that square hole that would hold a screw ? Will try to post pics later of it but hoping someone can help
Also, having trouble figuring out if I need sail panels.....If I remember right my car had them...Does anyone have a picture of their head liner installed but before the sail panels ? Just trying to picture how this area goes back together also. It looks like the 'toothed" brackets go all the way to the bottom of the rear window in the sail panel area so that is confusing me.
Re: 68 coronet headliner details [Re: belv2vert66] #1582779
02/23/14 01:18 PM
02/23/14 01:18 PM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
The 68 B bodies I have seen generally do not use sail panels. That is why the sharp teeth you speak of are mounted down by the package tray lower rear window. If sail panels are used those sharp tooth mounts are about mid way down the sail panel.
Re: 68 coronet headliner details [Re: pro-streeter] #1582780
02/24/14 12:50 PM
02/24/14 12:50 PM
PEI Canada
chromedome426 Offline
PEI Canada
My 68 has the teeth going to the bottom but also has the extra set of gripper teeth for the roof liner that uses the exposed sail panel.
If you don't have this set of gripper teeth, then your car had the full roof liner with the hidden sail panel.
Re: 68 coronet headliner details [Re: chromedome426] #1582781
02/24/14 12:58 PM
02/24/14 12:58 PM
PEI Canada
PEI Canada
Here is a pic of the hidden sail panel used underneath the full roof liners.
Held in place with a single nail pin.
Re: 68 coronet headliner details [Re: chromedome426] #1582782
02/24/14 03:53 PM
02/24/14 03:53 PM
Back In Iowa
Back In Iowa
Perfect ! Just what I needed to see. My car did not have the vertical gripper teeth. So no seperate sail panels. I am assuming that the headliner is contact glued down on the package tray then to keep it tight?
Does anyone reproduce the hard board piece that goes underneath the headliner ? And the nail holding it drives into what ? Any detail on that would be great
Thanks for all the answers guys ! I appreciate it !
Any words of wisdom on the front windsheild headliner moulding ?I am thinking the same clip might be used all the way across and I need 6 instead of 4 ?
Re: 68 coronet headliner details [Re: belv2vert66] #1582783
02/24/14 04:25 PM
02/24/14 04:25 PM
PEI Canada
PEI Canada
Yes.......roof liner is glued to metal package tray. Six clips across the front sounds correct. Dante's sell the cardboard. There is a hole in the C piller (seen in 1st pic) that I assume is for the nail pin to snap into.
Re: 68 coronet headliner details [Re: chromedome426] #1582784
02/24/14 10:51 PM
02/24/14 10:51 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Cars built up to approximately May 20th use the full headliner.Cars built after May 20th have the sail panels.
"Long Live Mopars"
Re: 68 coronet headliner details [Re: Furyman] #1582785
02/25/14 04:17 AM
02/25/14 04:17 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The early & late '68 RoadRunners I've owned seem to support what Furyman says; late ones had separate & visible sail panels. All except one (early car) are/were St. Louis cars. In all honesty I don't recall that detail in my early L.A. RR.
