Possible Hydrolock Issue #1582623
02/22/14 11:29 PM
02/22/14 11:29 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
My idiot brother hydroplaned my sister's '01 Ford Sport Trak into a water-filled ditch Thursday night. I took a look at it today & couldn't detect water in the cylinders but the intake plenum was very wet so I used the shop vac on that. Tried to turn it over (with the starter) to see if water would shoot out of the cylinders but it doesn't move, sounds like a dead battery or bad starter. Checked the battery & it's good, no reason to suspect the starter. Does it sound like it's hydrolocked? Never had this issue before so any input would be welcomed.
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: Possible Hydrolock Issue [Re: GTX4spd] #1582624
02/22/14 11:43 PM
02/22/14 11:43 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Drain the oil pan, pull the plugs and crank it, that should expel any excess water. if hasn't been wet too long, fill her up with oil put the plugs in and give it a go.
Joe
Re: Possible Hydrolock Issue [Re: GTX4spd] #1582625
02/22/14 11:44 PM
02/22/14 11:44 PM
Kirkland, Washington
Pacnorthcuda Offline
Pull the plugs, then turn it over. Also take close look at the oil.
Re: Possible Hydrolock Issue [Re: Pacnorthcuda] #1582626
02/22/14 11:46 PM
02/22/14 11:46 PM
IN
GTX4spd Offline OP
GTX4spd  Offline OP
IN
Yeah, I pulled the plugs & tried to crank it but got nothing. Didn't try cranking it manually yet, just not feeling up to it.
Re: Possible Hydrolock Issue [Re: GTX4spd] #1582627
02/22/14 11:57 PM
02/22/14 11:57 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
(Glad I'm not the only one with an idiot brother...)
Re: Possible Hydrolock Issue [Re: MoparMarq] #1582628
02/22/14 11:58 PM
02/22/14 11:58 PM
I wish mine was only an idiot.
Re: Possible Hydrolock Issue [Re: Pacnorthcuda] #1582629
02/23/14 12:22 AM
02/23/14 12:22 AM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
bought a 92 dakota 318 that sucked water ,was locked up.bent rod and bad piston. could also have bent valves
Re: Possible Hydrolock Issue [Re: d-150] #1582630
02/23/14 12:39 AM
02/23/14 12:39 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If it won't crank by the starter and the battery is charged, and the only thing that happened was that he sucked down a bunch of water by forging through a flood.... I'd be afraid the motor is a mangled mess inside. Fluids don't compress. Metal bends and cracks.
**Photobucket sucks**
Re: Possible Hydrolock Issue [Re: 70Cuda383] #1582631
02/23/14 01:03 AM
02/23/14 01:03 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
what if its a bad starter ?
crank it by hand , if it doesnt move -your brothers an idiot
Re: Possible Hydrolock Issue [Re: Pacnorthcuda] #1582632
02/23/14 10:07 AM
02/23/14 10:07 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Sadly,
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Possible Hydrolock Issue [Re: sogtx] #1582633
02/23/14 11:50 AM
02/23/14 11:50 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
it's possible, but how likely is it that the starter goes bad from one heavy splash/submersion?
Re: Possible Hydrolock Issue [Re: 70Cuda383] #1582634
02/23/14 12:02 PM
02/23/14 12:02 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Thats what I was thinking, I suspect the motor is toast.
I'd try some slip joint pliers on the alt or ps pump and see if the motor turns over first. Quick and easy test. If you can rock the motor back and forth then it might be a starter.
"I think its got a hemi"
Re: Possible Hydrolock Issue [Re: gdonovan] #1582635
02/23/14 12:06 PM
02/23/14 12:06 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Had a friend drive his Ranger through a small creek while 4-wheeling.It died,so they dragged it down the road trying to pop start it....bent all 6 connecting rods Yep..it was full of water. The air intake is pretty low in the grill if I remember correctly.
Re: Possible Hydrolock Issue [Re: GTX4spd] #1582636
02/23/14 01:58 PM
02/23/14 01:58 PM
If there's a bolt on the front so you can hand crank it with a breaker bar like we can then I'd pull the plugs & see if it is free. I'm assuming there is no bolt as that'd be the first thing to do. As you said no reason for the starter to have died at that point in time, same with the battery.
Re: Possible Hydrolock Issue [Re: GTX4spd] #1582637
02/23/14 02:06 PM
02/23/14 02:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Smacking water does tend to shock the chassis. Something might have rattled loose.
Being all computerized, your no starter issue might very well be electronics related, not like the old days when things were real simple. Does the starter even make any noise or appear to attempt to turn over? Did the inertia switch trip? I forget if they DOA kill starter or just the fuel pump.
Don't be the exception.
Re: Possible Hydrolock Issue [Re: GTX4spd] #1582638
02/23/14 02:23 PM
02/23/14 02:23 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
my son did the same thing with his escort a year ago. after days of trying to get it to turn over i discovered the a small amount of water had gotten into the cylinders via the intake and because the car had been outside all this time the water had frozen the pistons. i put a heater in the engine compartment and covered it up for a couple of hours and viola! i never thought about it because it was in the upper 30's but it never got warm enough to melt the ice.
Re: Possible Hydrolock Issue [Re: 70Cuda383] #1582639
02/23/14 03:45 PM
02/23/14 03:45 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
It is very likely. When I worked as a wrench every time we had a rainfall that flooded the storm drains (aka water on the streets) we were changing out starters left and right.
Re: Possible Hydrolock Issue [Re: Jeremiah] #1582640
02/23/14 04:36 PM
02/23/14 04:36 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i also suspected the starter and the battery and changed out both. it was because the pistons were frozen from about 1/8 inch of water in 2 cylinders and the crank/pistons wouldn't move.....my clue was when i did what Robert suggested above and tried to move the crank with a crowbar. couldn't budge it!
Re: Possible Hydrolock Issue [Re: GTX4spd] #1582641
02/23/14 05:05 PM
02/23/14 05:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most newer starters arent like the old ones.Different insides.If you smack them with a hammer like old ones to get them to start they will crack inside.I had a Pontiac at work that a guy drove thru a flooded street.Died and the whole air box was full.that and it wouldnt crank.Sat inside for a few hours and pulled plugs and finally cranked.New plugs,oil change and air filter and all was good.Rocky
Chrysler Firepower
Re: Possible Hydrolock Issue [Re: therocks] #1582642
02/23/14 10:05 PM
02/23/14 10:05 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does it have a factory anti theft or alarm system ? My Lexus would disable the starter if its system was triggered. I don't know how your idiot brother got out after it went in the drink but if he went out thru a window with the doors locked and then somebody reached in to open the door, that could trigger the system.
If it has a system do the reset procedure and see if it will crank.
Kevin
