70 RR- Gas Tank filler install... #1582562
02/22/14 09:53 PM
02/22/14 09:53 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
What is the right sequence to install the filler neck..? Grommet in the tank and then try to get the filler neck in... of put grommet on the neck first....?? Not easy.....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR- Gas Tank filler install... [Re: JMCFAN] #1582563
02/22/14 10:41 PM
02/22/14 10:41 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
grommet in tank first, then slip in filler neck(try a little wd -40) did u get that e brake piece I sent u ?
Re: 70 RR- Gas Tank filler install... [Re: pattyboy 572] #1582564
02/22/14 10:51 PM
02/22/14 10:51 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Yes I did! Today! Had to pick it up at post office! Thank you!!!
Re: 70 RR- Gas Tank filler install... [Re: JMCFAN] #1582565
02/22/14 10:55 PM
02/22/14 10:55 PM
new york usa
P
P
new york usa
great ....hope it helps u
Re: 70 RR- Gas Tank filler install... [Re: pattyboy 572] #1582566
02/22/14 11:14 PM
02/22/14 11:14 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
It sure did!!
Re: 70 RR- Gas Tank filler install... [Re: JMCFAN] #1582567
02/24/14 07:00 PM
02/24/14 07:00 PM
Gladstone, Michigan
UP FM3challenger Offline
Gladstone, Michigan
Silicone spray works well as an install lube and doesnt leave a mess.
Re: 70 RR- Gas Tank filler install... [Re: UP FM3challenger] #1582568
02/24/14 07:20 PM
02/24/14 07:20 PM
Washington State
70_FY1_N96_BEEP Offline
Washington State
Just put mine in last night. New ECS tank installed Saturday. I sprayed windex on my filler tube. Real nice tight fit, no binding. But after mounting the bracket and clamp, the filler tube raised up a tad so it's not 90 degrees to the grommet. I don't think it will be an issue though.
