5.2 magnum heads #1582456
02/22/14 04:33 PM
02/22/14 04:33 PM
c.t.
E
eric kuter Offline OP
E
c.t.
What is the best cylinder heads for 2000 dodge ram 5.2 magnum new castings ?
Re: 5.2 magnum heads [Re: eric kuter] #1582457
02/22/14 05:18 PM
02/22/14 05:18 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Re: 5.2 magnum heads [Re: Geezer] #1582458
02/23/14 11:55 AM
02/23/14 11:55 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
casting material? cost?
best would be Magnum Edelbrock Aluminum heads, or something from Indy that's designed to use the pedistal rockers and oil through pushrods.
but those will also be expensive. The edelbrocks will support 500 crank hp out of the box, but will run you $1600
EQ heads are a good choice, and can be opened up with port work to make some serious power, but they are iron which weighs more and you'll have to pay attention to compression. a decent set of unported heads will run you $800, but as soon as you start porting, you're looking at $1500-2000.
**Photobucket sucks**
Re: 5.2 magnum heads [Re: eric kuter] #1582459
02/23/14 01:38 PM
02/23/14 01:38 PM
c.t.
E
E
c.t.
It will be a stockrebuild i know the stock heads crack mine did passenger side only any other options. thanks eric
Re: 5.2 magnum heads [Re: eric kuter] #1582460
02/24/14 01:15 AM
02/24/14 01:15 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If its just a generic stock rebuild then consider having hardened seats pressed in by a competent machine shop. Cost will probably be less than buying new heads and having them set up.
Otherwise, you could look at the EQ heads. New castings that are better than the production heads.
Re: 5.2 magnum heads [Re: 70Cuda383] #1582461
02/24/14 03:40 PM
02/24/14 03:40 PM
c.t.
E
E
c.t.
No new valve seats fixing drivers side head leaked anit frezz into cyl eq the only one some head companies say new castings but give no casting # in the ad thanks again
Re: 5.2 magnum heads [Re: eric kuter] #1582462
02/24/14 11:34 PM
02/24/14 11:34 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Procomp china castings are available,better but not needed for a stock rebuild are the EQ's. Another option is to do a VJ on the cracked stockers and go unless it's spitting water. LOL
Re: 5.2 magnum heads [Re: goldmember] #1582463
02/26/14 04:57 PM
02/26/14 04:57 PM
c.t.
E
E
c.t.
Yes head is cracked any one use or deal with odessa cyl head company i am in c.t any one closer i found. them on ebay. thanks for the help
Re: 5.2 magnum heads [Re: eric kuter] #1582464
03/03/14 08:21 PM
03/03/14 08:21 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I got my EQs from Clearwater Cylinder in Florida. Not sure that is any closer.
Craig
Re: 5.2 magnum heads [Re: denfireguy] #1582465
03/04/14 03:25 AM
03/04/14 03:25 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Craig
Same company.
Re: 5.2 magnum heads [Re: goldmember] #1582466
03/05/14 03:23 PM
03/05/14 03:23 PM
dogdays Offline
dogdays  Offline
www.rlengines.com
www.rogersperformance.com
Google EQ heads Connecticut or New England and see.
R.
