scream'n SBM head choice #1582001
02/21/14 05:06 PM
02/21/14 05:06 PM
Madison, Wisconsin
chrisnben Offline OP
Madison, Wisconsin
Hey guys- looking for some input on head choice and what people are running. It's been a LONG time on a LA build for me. Putting together a 340 street/strip (OK- a strip car with turn signals and looking at a set of ported W2's & victor intake VS some Eddy RPM's run through a CNC porting job.
RPM range 3000-7500; 727 trans; 4.10's; not sure on cam yet-probally Comp XE 285/545 range
Any thoughts on the two?
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: scream'n SBM head choice [Re: chrisnben] #1582002
02/21/14 05:20 PM
02/21/14 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depending on the port job on the W-2s.. but they will
flow more if done right... BUT they are iron so thats
40# more on the front end... so basically its a wash..
I run the W-2s on my Rampage and its in the 580 hp
range for a street/strip mainly street... but I'm
still looking to get my W-5s fixed to use them... also
I'd look for a better cam.... JMO
Re: scream'n SBM head choice [Re: MR_P_BODY] #1582003
02/21/14 05:54 PM
02/21/14 05:54 PM
Madison, Wisconsin
Madison, Wisconsin
Mr. P, yeah the 40# is some weight, but currently she's got a RB in there all aluminum except the block- so roughly about the same as the LA iron set-up. I have to buy headers either way, so yes it is a wash.
Any good cam recommendations? What's in the Rampage?
Re: scream'n SBM head choice [Re: chrisnben] #1582004
02/21/14 06:16 PM
02/21/14 06:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The cam I have in the Rampage is a old MP roundy round
roller that I had laying around the shop(that whole
engine is just shop junk except for the lower compression
pistons).. but its a 260/270 .640/.640 with a 105 lsa
installed at 105... this is a 416ci
Re: scream'n SBM head choice [Re: MR_P_BODY] #1582005
02/21/14 06:20 PM
02/21/14 06:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Your best bet is to decide on what heads you are going to run and get some flow numbers at every .050 BEFORE starting to decide on a cam. Flow and compression ratio make cam choose a lot easier and is the right way to go about it. Converter stall also is a big player.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: scream'n SBM head choice [Re: pittsburghracer] #1582006
02/21/14 06:27 PM
02/21/14 06:27 PM
Madison, Wisconsin
Madison, Wisconsin
yep- you got it. What's the good word on rods for a 7000 rpm 340 these days?
Re: scream'n SBM head choice [Re: chrisnben] #1582007
02/21/14 06:30 PM
02/21/14 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use H-beams in all my junk... I bought a few sets
of Eagle H-beams years ago and they've great in my stuff
Re: scream'n SBM head choice [Re: MR_P_BODY] #1582008
02/21/14 07:08 PM
02/21/14 07:08 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Sense you are changing everything. Headers bell housing etc. And you want something that will scream. You really should look at a R5P7. The cost would turn out roughly the same. You can run an adapter between the engine and your big block transmission.
Leon
Re: scream'n SBM head choice [Re: Leon441] #1582009
02/21/14 07:12 PM
02/21/14 07:12 PM
Madison, Wisconsin
Madison, Wisconsin
Leon
what's the brand and is it cost effective for an adapter?
Re: scream'n SBM head choice [Re: chrisnben] #1582010
02/21/14 08:39 PM
02/21/14 08:39 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
If you have not already bought a crank you can get one with 2.100 or 2.000 rod journals. BPE and callies make them. Then you can get 6.125, 6.200, 6.250 and even 6.300 length rods, with sm. chevy big end and pin dimensions. Plenty of good rods out there. Wiseco, diamond and others have shelf pistons with .927 pins and will do one change to the piston for $5 a piston. That way you can put the longer rod in and have a shorter lighter piston.
On the cyl heads, there is a new one out, and I believe in stock now called Airwolf, flows over 300CFM, and uses ordinary LA parts. There has been lots of talk about airwolfs on this site.
Re: scream'n SBM head choice [Re: chrisnben] #1582011
02/21/14 08:45 PM
02/21/14 08:45 PM
Renton Washington
Triple Threat Offline
Renton Washington
There is a set of W2's with intake and rockers in Race parts for sale for a really good deal. FYI
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: scream'n SBM head choice [Re: Triple Threat] #1582012
02/22/14 03:18 AM
02/22/14 03:18 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I would not run a hydraulic camshaft!!! And in my opinion, any cylinder head that gets rid of the pushrod pinch is going to have more potential. Therefore I personally believe the w2 has more potential for more horsepower.
But I also think that a ported edelbrock is plenty for only 340 cubes, and is going to make more midrange torque, be lighter, and have better combustion chamber. And personally, with only 4.10 gears and a somewhat tight converter that you plan, I feel the edelbrock may work better, due to the smaller intake port for better air speed and torque.
There is also the Indy ta head that is a edelbrock that the pushrod holes are moved, and they use a 440 rocker system and factory intake and header patterns.
Re: scream'n SBM head choice [Re: MR_P_BODY] #1582013
02/22/14 05:08 AM
02/22/14 05:08 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
[/quote
What happen to your w5 ????
Re: scream'n SBM head choice [Re: chrisnben] #1582014
02/22/14 11:34 AM
02/22/14 11:34 AM
Az
Crizila Offline
Crizila  Offline
Az
Fully ported Edelbrocks from Hughes. Advertised to flow .299 @ .700. You can use all stock valve train and exhaust stuff.
Fastest 300
Re: scream'n SBM head choice [Re: Crizila] #1582015
02/22/14 11:35 AM
02/22/14 11:35 AM
Az
Crizila Offline
Crizila  Offline
Az
chambers
Fastest 300
Re: scream'n SBM head choice [Re: RAY1969CARS] #1582016
02/22/14 12:03 PM
02/22/14 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
[/quote
They were leaking oil into the cylinders big time..
a qt every 35 miles... I finally put my W-2s on and
the issue went away.... when I get back home I'll
take a look at them to find the problem
Re: scream'n SBM head choice [Re: qwkmopardan] #1582017
02/22/14 12:50 PM
02/22/14 12:50 PM
Madison, Wisconsin
Madison, Wisconsin
I did the same thing on my 440 stroker with the .927 pins & SBC big ends on a custom Ross piece. Man, together they weigh just over 1000g! That engine really wraps up fast for a 489. I probally will go with the same set-up on the LA bottom end.
As far as the heads, well I might just grab those W2s for sale here and save $1500. over ported Eddys, Indys, Airwolfs, etc. Not to mention the W2s come with HSharp rollers and Victor intake.
Re: scream'n SBM head choice [Re: chrisnben] #1582018
02/22/14 01:01 PM
02/22/14 01:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like a good package
Re: scream'n SBM head choice [Re: chrisnben] #1582019
02/23/14 02:44 AM
02/23/14 02:44 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Now spend some of that money on a good head porter and be way head of the game.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: scream'n SBM head choice [Re: 1967dartgt] #1582020
02/23/14 03:35 AM
02/23/14 03:35 AM
V
viperblue72 Offline
viperblue72  Offline
V
I still think the w2 head is the best bang for buck if you don't already have headers, intake, etc.
I don't think you will go wrong with that deal.
