Ebody heater switch panel #1581802
02/21/14 12:16 AM
02/21/14 12:16 AM
Oreland Pa
clonedshaker+6 Offline OP
Oreland Pa
so im restoring my heater switch panel and a lot of the textured flat black paint is worn off, what paint should I use to restore this thing so it looks new?
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present)
03 mustang Mach 1 (daily driver)
11.35 @ 121.5 4 SPEED on F60-15s w/ 6/32 tread
Re: Ebody heater switch panel [Re: clonedshaker+6] #1581803
02/21/14 12:41 AM
02/21/14 12:41 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Plasticoat #217 works great. Follow directions carefully. I don't have the can in front of me but if it doesn't say to, put the part in a 100 degree oven for an hour after spraying.
Re: Ebody heater switch panel [Re: drew72] #1581804
02/21/14 01:33 AM
02/21/14 01:33 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I sprayed the bezel with SEM trim black first...then masked off the center rectangle and sprayed VHT wrinkle paint. I set it out in the sun to wrinkle but you can use a heat gun to speed up the process.
