Any Difference between DODGE hood and trunk letters?? #1581788
02/20/14 11:16 PM
02/20/14 11:16 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
I may have mine reversed....lol Are the Hood letters thinner than the trunk letters?? The guy doing mine is going to check tomorrow but I was just wanting to know .......
Thanks,Tony
Finally Done....BEERS!!!
Re: Any Difference between DODGE hood and trunk letters?? [Re: holtzdog55] #1581789
02/20/14 11:18 PM
02/20/14 11:18 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The hood letters are thin and flat. The tail panel letters are thick and curved to fit the contour of the tail panel.
You have the tail panel letters on the hood. Originally, they weren't painted black on the sides.
Re: Any Difference between DODGE hood and trunk letters?? [Re: burdar] #1581790
02/20/14 11:19 PM
02/20/14 11:19 PM
Fairfield, Ohio
Fairfield, Ohio
Cool...Thanks...I thought so....
Re: Any Difference between DODGE hood and trunk letters?? [Re: holtzdog55] #1581791
02/21/14 02:48 PM
02/21/14 02:48 PM
Fairfield, Ohio
Fairfield, Ohio
OK....Looks like I have 2 sets of tail panel DODGE letters ......Does anyone have the HOOD letters for a 70 71 Rallye hood??? the pins match up with the tail letters pins.....the repros I hear dont match up with the original holes.........
Re: Any Difference between DODGE hood and trunk letters?? [Re: holtzdog55] #1581792
02/21/14 02:55 PM
02/21/14 02:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I bought my hood letters from Herb's Parts. They fit great. I'd heard of problems with the "G" being smaller then the others...no problem with mine. They are all the same size.
Re: Any Difference between DODGE hood and trunk letters?? [Re: burdar] #1581793
02/21/14 03:00 PM
02/21/14 03:00 PM
Fairfield, Ohio
Fairfield, Ohio
Were they rpro's?? Did the pins line up the same? I heard some have pins in different corners.....
Re: Any Difference between DODGE hood and trunk letters?? [Re: holtzdog55] #1581794
02/21/14 04:50 PM
02/21/14 04:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes, they were repops from Herb's. They fit great. I reused the factory stamped nuts. I thought I heard the letters were back ordered at one time. Hopefully they have them in stock.
I looked but I don't have a picture of them on the front. My tail panel letters also came from Herb's.
Re: Any Difference between DODGE hood and trunk letters?? [Re: burdar] #1581795
02/21/14 06:12 PM
02/21/14 06:12 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
It seems rechroming the letters usually give less than satisfactory results no matter which plater you use..They were a badly needed repop..
