Page 2 of 3 1 2 3
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581558
02/21/14 01:36 AM
02/21/14 01:36 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#3
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581559
02/21/14 01:37 AM
02/21/14 01:37 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#4
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581560
02/21/14 01:37 AM
02/21/14 01:37 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#5
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581561
02/21/14 01:38 AM
02/21/14 01:38 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#6
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581562
02/21/14 01:38 AM
02/21/14 01:38 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#7
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581563
02/21/14 01:39 AM
02/21/14 01:39 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581564
02/21/14 01:39 AM
02/21/14 01:39 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#8
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581565
02/21/14 01:39 AM
02/21/14 01:39 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#9
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581566
02/21/14 01:40 AM
02/21/14 01:40 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#10
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581567
02/21/14 01:40 AM
02/21/14 01:40 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#11
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581568
02/21/14 01:41 AM
02/21/14 01:41 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
#12
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581569
02/21/14 01:42 AM
02/21/14 01:42 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Hope these helped
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
Re: Dash pictures 68-70? [Re: 5wndwcpe] #1581570
02/21/14 02:01 AM
02/21/14 02:01 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here is the only difference I found between a '68 and '69 wiring harness. This is the reason the parking lights go off on a '68 when the headlights are turned on. And I kind of think I know the engineering reason for this.
Note that your '68 has the yellow s/black tracer wire on the light switch plug and the '69 plug I'm posting has no yellow wire
Re: Dash pictures 68-70? [Re: A12] #1581571
02/21/14 02:18 AM
02/21/14 02:18 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
Thanks Pete and Mike...that's why I absolutely love this board...thanks guys, awesome info and pics. Of all of the things about restoring this GTX the dash has me the most perplexed...maybe it should or shouldn't but wiring makes me nervous and it have spent soooo much money and time with this car I really don't want to miswire or (gulp) fry anything. JS restorations did an outstanding job on the harness and switches, Just Dashes did the pads, Wards Radio did the radio, and Hodges Restorations did the dash frame and now Im waiting on the gauge cluster from Auto Instruments...then...all I have to do is put it together.... Pics coming
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Dash pictures 68-70? [Re: RapidusMaximus] #1581572
02/21/14 02:56 AM
02/21/14 02:56 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I had two like new parts car wiring harnesses from two 1968 road runners and I debated about buying a reproduction '69 harness so I printed both the '68 and '69 wiring schematics from here: http://www.mymopar.com/index.php?pid=27 and http://www.mymopar.com/index.php?pid=18 and then tracked/traced EVERY wire on both the '68 and '69 schematics and learned a lot about the where and why and also the one small difference between the two. I'd start at a switch or point on the dash and work toward the firewall junction and the fuse box and then to the alternator, relay, and battery. That's how I found the yellow with black tracer missing on the '69.....because it doesn't have four side marker lights just side reflectors. I think engineering wise they turned the front parking lights off to minimize the demand for running the headlights along with the four side marker lights on the '68. Maybe the current demand for running the high and low four headlights, four side maker lights and two more front parking lights was deemed too much for the wiring system???
My first car in '69 was a brand new '69 road runner and I always remembered the parking lights being on with the headlights. When I got the '68 road runner I thought there was a problem with the wiring when the parking lights would go out when I turned on the headlights then I was told they go off on the '68's when the headlights went on.....and then it hit me with the side marker lights Oh it's been lots of fun learning even as I get older
Re: Dash pictures 68-70? [Re: A12] #1581573
02/21/14 08:30 AM
02/21/14 08:30 AM
Weatherford, Texas
Weatherford, Texas
Thanks, I'm going to see if I can open that link at work and print the diagrams on blue print size paper
1968 Plymouth GTX
Re: Dash pictures 68-70? [Re: A12] #1581574
02/21/14 07:47 PM
02/21/14 07:47 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
to the right of the instruments/speedometer/AC vents
Whats diffent here?
And if your redoing the wiring your almost better off pulling the window and the dash so you can work on it with out a head rush.
2 '68 dash lower padsand a '69 pad
Mike, I can use that 69 tan pad for my R/T
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Dash pictures 68-70? [Re: AZ_A12_BEE] #1581575
02/21/14 10:36 PM
02/21/14 10:36 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Dash pictures 68-70? [Re: A12] #1581576
02/21/14 10:43 PM
02/21/14 10:43 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Pad tease
Re: Dash pictures 68-70? [Re: AZ_A12_BEE] #1581577
02/22/14 04:13 PM
02/22/14 04:13 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Pad tease
Hmmmmmmmmmmmm I wonder if I do have the upper dash pad too
Page 2 of 3 1 2 3
