replacing small block oil pump #1581298
02/19/14 04:46 PM
02/19/14 04:46 PM
Oly Wash
racerlall Offline OP
Oly Wash
can a small block oil pump be replaced in a 65 b body without pulling the engine thanks E.
Re: replacing small block oil pump [Re: racerlall] #1581299
02/19/14 04:52 PM
02/19/14 04:52 PM
Probally, when you say Small Block I assume your saying the LA type engines, not the original Poly headed 318 Is this a OEM 273 C.I. motor? If so you should be able to change it easily
Re: replacing small block oil pump [Re: Cab_Burge] #1581300
02/19/14 05:00 PM
02/19/14 05:00 PM
Oly Wash
Oly Wash
its a poly but the bottom end shod be the sane right
Re: replacing small block oil pump [Re: racerlall] #1581301
02/19/14 05:43 PM
02/19/14 05:43 PM
P
Paul_Fancsali Offline
P
Just be sure to prime the pump with oil before buttoning up
Re: replacing small block oil pump [Re: racerlall] #1581302
02/19/14 05:59 PM
02/19/14 05:59 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes getting the oil pan off can be a pain but once thats done its easy. Lifting the engine an inch or 2 off the mounts also helps.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: replacing small block oil pump [Re: racerlall] #1581303
02/19/14 06:23 PM
02/19/14 06:23 PM
As said undo what needs to be undone so you can raise it several inches. May I ask what psi readings you are dealing with? If it's an extremely worn eng I would go with a hi vol pump if the std vol pump/hi psi spring cannot maintain adequate flow (psi)
Re: replacing small block oil pump [Re: RapidRobert] #1581304
02/19/14 06:41 PM
02/19/14 06:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the oil pressure is really low just install a new set of rod and main bearings while the pan is off. Not that hard to do.
Re: replacing small block oil pump [Re: stumpy] #1581305
02/20/14 05:42 AM
02/20/14 05:42 AM
Oly Wash
Oly Wash
its a high mileage car oil presser is low but not zeroed out yet iv got a new mystery pump on the shelf it looks like a OEM or melling casting I think its likley a stock replacement
Re: replacing small block oil pump [Re: racerlall] #1581306
02/20/14 09:42 AM
02/20/14 09:42 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
it can be done with a 318 poly. I did it when my coronet still had the poly in it.
Re: replacing small block oil pump [Re: 65rbdodge] #1581307
02/20/14 11:56 AM
02/20/14 11:56 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Do Not just install new bearings in the bottom end until you've Plastigauged them to know What size is needed. Throwing standard in when you need the next size defeats the purpose.
Re: replacing small block oil pump [Re: racerlall] #1581308
02/20/14 01:36 PM
02/20/14 01:36 PM
I'd slap in a hi vol sealed power or melling pump. Extremely likely the bearings are OE std. wouldn't hurt to replace em with some std's if you felt comfortable tackling that job. the rod bearings would be a piece of cake, the mains are more involved changing them & as you know as soon as the (rod) cap comes off slip some tubing on the bolts to cover the threads
Re: replacing small block oil pump [Re: 76dodgeboy] #1581309
02/20/14 01:36 PM
02/20/14 01:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If it's a standard crank that has worn to the point where standard bearing don't work he needs machine work before he can run undersized bearings
Don't be the exception.
Re: replacing small block oil pump [Re: Supercuda] #1581310
02/20/14 01:42 PM
02/20/14 01:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the oil pressure is just low I doubt very seriously that the crank is worn enough to need over sized bearings. Remember the bearings are meant to wear long before the crank is.
Re: replacing small block oil pump [Re: racerlall] #1581311
02/20/14 02:03 PM
02/20/14 02:03 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If (with a real gauge) has 5psi or better @ hot idle and the pressure rises with RPM I'd leave it alone.
Re: replacing small block oil pump [Re: goldmember] #1581312
02/20/14 02:11 PM
02/20/14 02:11 PM
Excellent point, especially for a DD that ain't being hotrodded & from what I gather I'm assuming that ain't the case here. That'd involve alot of work for (maybe) not much gain & the gain might not be critical in this app
Re: replacing small block oil pump [Re: racerlall] #1581313
02/20/14 03:20 PM
02/20/14 03:20 PM
Are you using a good mechanical oil pressure gaue? If so how low does it drop to idling in gear hot? how much does it have when cold idling? Last thing is how much pressure does it have when you are driving it down the road with hot oil? If it has 10 lbs per 1000 RPM when hot going down the road run it until you want to find out what is causing the problem If less than 10 lbs per 1000 RPM fix it ASAP
Re: replacing small block oil pump [Re: 76dodgeboy] #1581314
02/20/14 04:43 PM
02/20/14 04:43 PM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
It wouldn't be a total waste of time, would it? Replacing the worn bearing material would still be an improvement I would think. I mean, at that point, it's really just a band-aid before a proper rebuild anyway.
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: replacing small block oil pump [Re: stumpy] #1581315
02/20/14 07:16 PM
02/20/14 07:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you read the post I responded to?
Re: replacing small block oil pump [Re: Supercuda] #1581316
02/20/14 07:26 PM
02/20/14 07:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes, and your point is?
