Re: replacing small block oil pump
[Re: racerlall]
#1581302
02/19/14 05:59 PM
02/19/14 05:59 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes getting the oil pan off can be a pain but once thats done its easy. Lifting the engine an inch or 2 off the mounts also helps.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: racerlall]
#1581303
02/19/14 06:23 PM
02/19/14 06:23 PM
RapidRobert
As said undo what needs to be undone so you can raise it several inches. May I ask what psi readings you are dealing with? If it's an extremely worn eng I would go with a hi vol pump if the std vol pump/hi psi spring cannot maintain adequate flow (psi)
[Re: 76dodgeboy]
#1581309
02/20/14 01:36 PM
02/20/14 01:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If it's a standard crank that has worn to the point where standard bearing don't work he needs machine work before he can run undersized bearings
