5.9 24V Cummins Question #1581215
02/19/14 02:06 PM
02/19/14 02:06 PM
Nebraska
CumminsGirl08 Offline OP
Nebraska
So i am looking to purchase this 2001 Cummins 5.9L 24V and it has 190K miles on it. I have had mixed reveiws about if i should do it or not. I was told that anything under 200K is just breaking in the motor. Is this true?? Can you guys help me so i know a little bit more about what i am getting myself into?
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581216
02/19/14 02:17 PM
02/19/14 02:17 PM
dogdays Offline
dogdays  Offline
Drove a '99 for three months, it had around 170K on it, no problems except the battery posts needed cleaning up.
R.
Re: 5.9 24V Cummins Question [Re: dogdays] #1581217
02/19/14 02:27 PM
02/19/14 02:27 PM
Nebraska
Nebraska
thank you for your input!! I will take that into consideration when i go look at the truck in person!
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581218
02/19/14 03:41 PM
02/19/14 03:41 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Valves should have been adjusted @ 150,000 miles. The lift pump is a weak point. Check if an aftermarket solution has been installed, Vulcan, FASS or Airdog, all upgrades over the factory pump.
Battery cables are expensive, check condition. Check dash carefully for cracks or a cover. Another EXPENSIVE fix.
Mines at 128,000, been through all but the valve adjustment.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581219
02/19/14 03:53 PM
02/19/14 03:53 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Just like anything else in life...it all depends on how it has been treated by the PO. But first you should realize that a diesel truck is best used for accumulating a lot of miles in steady use and 190,000 miles in 13 years is only 14,610 miles per year and that is not good for it. Now maybe this was owned by a snowbird that used it to pull a 5th wheel to AZ or FL and then parked it for 6 months at a time and that might be all right...but not if they used it as a daily driver for a 5 day a week 10 mile commute BTW most Cummins will run 300K to 500K before overhauls with regular (expensive) maintenance.
Why do you need a diesel? They are more expensive to purchase and maintain than a gas rig, but make up for it in longevity and brute strength. But there is no reason to own a locomotive just to make trips to the local 7/11
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 5.9 24V Cummins Question [Re: Polarapete] #1581220
02/19/14 04:24 PM
02/19/14 04:24 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
01-02 are the best years, check to see if the injectors were changed or have had maintenance on them. I blew up 2 common rail Cummins engines due to injector neglect. Have the rear end and trans checked as the Cummins engine puts out enough torque to make those parts the weak point. If an automatic check the overdrive out, if a 4x4 check the transfer case and have a good look at the fluid in it.
JB Rhinehart, Realist
A-Body's RULE!
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581221
02/19/14 07:56 PM
02/19/14 07:56 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
I've got a 2001 245hp 6 speed 4x4 with 240000Km on it.
Overall it is a very good truck. As said, if the lift pump is still an original style (on the engine block) it will fail (if it hasn't already) and should be replaced with an aftermarket such as FASS or AirDog. The truck will still run with a failed lift pump, but it will destroy the injection pump due to lack of lubrication(expensive!).
The sure grip diff (if equipped) is a weak point as well. Mine is completely worn and makes some noise. Eaton has a Truetrac available for it.
Cracked dash is another expensive fix, and they all seem to break.
The turbo wastegate may seize and cause overboost defuelling (loss of power) if the truck is from the snowbelt.
Aluminum wheels are known to crack around the inner bead(as mine did).
Rusty door bottoms are very common.
Other than expensive regular maintenance, and the odd wheel bearing and U-joint, mine has been very reliable and tows great.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: 5.9 24V Cummins Question [Re: D149] #1581222
02/19/14 08:16 PM
02/19/14 08:16 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Most have already covered all the weak points of these years. Lift pump and or injection pump is a biggy. Even though I don't think I have abused my truck (2002 HO with 6spd manual, 2wd - only 61k miles on it now - owned since new), I still had to do the lift pump @ 40k miles and the injection pump. I am pretty nutso about maintenance. . . so other than that, the truck has been flawless . . . if you are getting to tow, you can't go wrong. Just make sure it is checked out thoroughly. Also can go to the dodge truck forum to see other issues . . .
Good luck
Cheers
Mark
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581223
02/19/14 09:24 PM
02/19/14 09:24 PM
California
Moneypit6 Offline
Moneypit6  Offline
California
As stated by others, lift pump and VP-44 injection pump are weak points. Many improvements have been made here over the years for replacements. 01 and 02 should be new enough to not be a 53 block which had a problem with cracking on the water jackets. Engine is built solid. Need clean air into the motor as they were a little susceptible to upper end problems. As long as these are understood, these motors /can/will pull for a long long time. Nothing like a good diesel setup for running on the road. Peak torque is right where you are driving!!
70 Roadrunner almost ready to come off the rotisserie smile
Re: 5.9 24V Cummins Question [Re: Moneypit6] #1581224
02/19/14 10:52 PM
02/19/14 10:52 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
with most of what has been stated by others. The engine itself I would not worry too much about. It its no big deal for them to go over several hundred thousand miles if maintained. Remember, you are still bying a truck with almost 200K on it. So dont be surprised if it needs some work. Most people that buy them dont generally use them to run to the grocery store, they work the hell out of them. This takes its toll on the truck. The stuff you are going have problems with are going to be with the truck itself and the fuel injection system. Lately I have been seeing more and more ECM, sensor, and wiring issues as these trucks age. That used to not be the issue but nothing lasts forever. Good luck.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581225
02/19/14 10:54 PM
02/19/14 10:54 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
check to see if there has been a gooseneck hookup in it, if there is or was one then there's no telling what it has pulled
Re: 5.9 24V Cummins Question [Re: 98RAM1500] #1581226
02/20/14 12:24 AM
02/20/14 12:24 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
after having owned one with that kind of mileage on it, all I'll say is expect a lot of minor repairs that will add up.
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581227
02/20/14 07:52 PM
02/20/14 07:52 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Good place to lurk for Cummins info.
http://www.cumminsforum.com/forum/
Re: 5.9 24V Cummins Question [Re: thehemikid] #1581228
02/22/14 10:11 AM
02/22/14 10:11 AM
Sandy, OR
DART67GT Offline
DART67GT  Offline
Sandy, OR
If it's a 4x4, see if the front end has been rebuilt. I just did mine at 140k. Steering box and everything. It now drives better than new. The factory steering components were sealed other than the upper ball joints.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581229
02/22/14 12:32 PM
02/22/14 12:32 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Bought my 02 4wd with 50k miles & drove it for another 100k. Great
truck that could get 20mpg on the highway & towed like a dream.
Here's some advice I learned the hard (expensive), way:
1. Don't tow in overdrive & you can, upgrade your trans for towing.
2. Don't use a first gen Edge EZ controller. After 3 yrs, mine shorted
out the PCM which took out the ECM, the injection pump & the lift pump.
Dodge employee cost was $7k to fix, so I sold it & built this...
(maybe one day, it'll get a cummins)
3. As others advised, weak link is the lift pump, so do some research
& upgrade to one of the good systems that are out there.
Oil changes are expensive & brake jobs, too, but the Cummins will outlast just about anything if well maintained.
Re: 5.9 24V Cummins Question [Re: Triggerfish] #1581230
02/23/14 09:47 PM
02/23/14 09:47 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
If you just use common sense you can tow in OD with no problems.
I have put tons of miles towing a 34' 16k pound 5th wheel and a 32' 12k pound enclosed race car trailer all over with zero problems out of trans.
Only time you need to take it out of OD is if it starts to shift hunt back and forth.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 5.9 24V Cummins Question [Re: CumminsGirl08] #1581231
02/25/14 06:38 PM
02/25/14 06:38 PM
an8sec70cuda Offline
Love mine. It's a 2001 quad cab 4x4 automatic w/ 190k on it. When I bought it it had 160k on it. An old man had it and pulled a camper w/ it.
If the truck you're looking at has an aftermarket lift pump on it, that's good. If it doesn't have one, you'll need to put one on it...as well as a fuel pressure gauge.
I have the Raptor lift pump kit on mine...do not get one of these, lol.
By now the front end has probably already been rebuilt. If it hasn't, it's surely worn out. It'll wander all over the road, but it can be fixed.
New ball joints, track bar, and one of those steering box stabilizer bars made a huge difference.
http://www.thoroughbreddiesel.com/sinister/steering-stabilizer.htm
I'm no help if it's a manual trans, but the automatics are fairly weak. I'm almost certain my truck has a re-man trans in it.
Parts for these trucks are WAY cheaper than the later model stuff.
If you like mud tires, you can fit 35s on them w/o doing anything else to it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 5.9 24V Cummins Question [Re: dusturbd340W5] #1581232
03/04/14 06:45 PM
03/04/14 06:45 PM
Laramie WY
0
07dodge Offline
07dodge  Offline
Laramie WY
Wow, gorgeous truck Triggerfish!
These guys pretty much covered it, although I would say I wouldn't be concerned over the miles vs age, these trucks aren't that fragile that it would be a huge factor.
Also, 24v's don't have the injector issues the Common Rails do; if a CR loses and injector, good chance of melting a piston and needing a rebuild (been there, done that), whereas a 24v or 12v loses an injector, you swap it and keep trucking.
07 Ram 3500-EFILive-Goerend Trans 03 Ram 2500-Smarty TNT/R-6.7 swap 70 Challenger 68 Roadruner 68 Satellite
