Picked up a 67 Dart that a guy was setting up to do a little drag racing. RB 512 stroker,compression should be around 10.5 or a little less. 0 decked. fired, no miles. Unported Stealth heads with Comp Cams XE295HL-10
Duration Intake 295 Exhaust 307
@.050 251 257
Valve lift 564
Lobe seperation 110
I tried calling Mr Porter about a cam, but couldnt get ahold of him. Plan on calling agian.
I want to put this 512 in my driver, some trips to the track 70 Charger with a 3.54 dana. The Dart has a new Turbo Action 17801 converter.I know theres better cams for exhaust manifolds, but my question is, could I run that cam with my manifolds? What could I expect performance wise?
Thanks Terry
