Restore dual snorkel air cleaner #1581025
02/18/14 11:12 PM
02/18/14 11:12 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Guys, I'll repaint a 1971 challenger dual snorkel air cleaner and rave some questions.
Is it texturized outside, inside and underside?
Is it mat black or semi gloss black?
Let me know Asap, Im rush on it.
Hi-res pics will be apreciated.
Re: Restore dual snorkel air cleaner [Re: v8punch] #1581026
02/18/14 11:15 PM
02/18/14 11:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Inside is smooth gloss black, outside is wrinkle finish.
Re: Restore dual snorkel air cleaner [Re: ScottSmith_Harms] #1581027
02/18/14 11:21 PM
02/18/14 11:21 PM
Shippensburg, PA
GardnersGotCudas Offline
Shippensburg, PA
what s the best paint to use on the out side
Re: Restore dual snorkel air cleaner [Re: GardnersGotCudas] #1581028
02/18/14 11:28 PM
02/18/14 11:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Try VHT black Wrinkle, or Harley Davidson Wrinkle (Harley dealers carry it). Either works great......The application is the tricky part, definitely takes some practice to get a nice even wrinkle finish without sags and runs, especially on vertical surfaces. Start with extremely clean bare steel and skip the primer, go right to paint. Pre heat the parts to about 150 with a heat gun (or best, in an oven) and remember, keep it clean from grease etc. Apply in three even coats spaced about 10 minutes apart.
Re: Restore dual snorkel air cleaner [Re: v8punch] #1581029
02/19/14 01:29 AM
02/19/14 01:29 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
had mine powder coated..while not 100% conours exact it was 15 yrs ago so maybe they have a closer texture now.. looks brand new still..
Re: Restore dual snorkel air cleaner [Re: ScottSmith_Harms] #1581030
02/19/14 01:33 AM
02/19/14 01:33 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
My car is in storage right now so I can't get a pic. I have a 71 bee same aircleaner and Scott is CORRECT smooth inside wrinkle out. I will try and search my records of what I used and get back to you. First one that I ever did and it came out great. I wills see what I can find for you tomorrow.
Re: Restore dual snorkel air cleaner [Re: 340cpe] #1581031
02/19/14 02:10 AM
02/19/14 02:10 AM
New State
kidmopar Offline
kidmopar  Offline
New State
"Try VHT black Wrinkle, or Harley Davidson Wrinkle (Harley dealers carry it)."
My :two cents:
Stick with the VHT Wrinkle Black .... The Harley Davidson paint is ( I M H O ) "NFG" ..
Re: Restore dual snorkel air cleaner [Re: ScottSmith_Harms] #1581032
02/19/14 10:11 AM
02/19/14 10:11 AM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
Thank's Guys, unfortunaly I'm far from Usa and VHT and HD cans are not options.
I'll send the filter to na eletrostatic paint shop, and paint it black wrinkle outside, and black inside.
