Running a block w/broken pass side bellhousing mount? #1581014
02/18/14 10:53 PM
02/18/14 10:53 PM
Pa
71nonRT340shaker Offline OP
Pa
Has anyone had any sort of luck when it comes to running a block that has the pass side rear mount/dowel area broken? My car shook like crazy, when I bought it years ago it wasn't running and may have very well saved the car. Dave at ATI spun the 10" converter that was in the car and found it to be 30 grams (about an ounce) out of round. Long story short I have a new 10" ATI converter, new flex-plate, ARP bolts for plate and converter. The trans was rebuilt including a new pump and bushing kit, also has a bolt in sprag all done locally by Will that runs the Ornery Cuss 72 Dart race car that has been around Pa for decades. It's taken 6 months to get everything rounded up/paid for and I for whatever reason missed the fact that the factory alignment dowel is completely AWOL. The dowel hole that you see in the pics was obviously added to the block and trans. The pin was pushed through the back side of the trans so when the two were mounted up the first time back in 83 they didn't make sure both pins were doing their job.
What next? Risk 2k worth new parts and a trans rebuild, or who knows how much to replace a solid 340 that runs great but is missing a key component? I'm torn but leaning towards taking my chances with what I have. The car wont be raced, and if it's driven over 500 miles a year that'd be a lot even with a 180 mile round trip to Carlisle. Thanks in advance, TC.
Also I'd like to add that in the event it would cure alignment issues I'm not afraid to use a mid-plate on the car and use spacers for the converter. I'm aware nothing about this is ideal but if I had to guess I would say the converter issue was due to neglect or even being a 'great deal' piece that should have been never been put in the car 30 years ago.
Here's a link to my last posts about the car and trying to troubleshoot from September: older post
Re: Running a block w/broken pass side bellhousing mount? [Re: 71nonRT340shaker] #1581015
02/19/14 02:53 AM
02/19/14 02:53 AM
All I can add is I just came from the tranny shop where they are setting up my gears & the owner was talking about a recent case where someone used an adapter (didn't get all the specifics) but a locating dowel was missing & it all fubared.
Re: Running a block w/broken pass side bellhousing mount? [Re: 71nonRT340shaker] #1581016
02/19/14 11:36 AM
02/19/14 11:36 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have two 340 blocks like yours, one is .040" over and the other is .060" over. Both of mine are going to the scrap yard.
Re: Running a block w/broken pass side bellhousing mount? [Re: 71nonRT340shaker] #1581017
02/20/14 02:28 AM
02/20/14 02:28 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If the dowel holes are intact. I'd run it.
The other bolts are nothing more than fasteners to hold the engine and transmission together. The dowels take ALL the shear load.
Re: Running a block w/broken pass side bellhousing mount? [Re: Magnum] #1581018
02/20/14 05:55 AM
02/20/14 05:55 AM
I would be tempted to find a empty SB 727 case and indicate the front pump sealing area to verify how much run out is on it, if it is more than .030 total run out I would buy some offset dowels and correct it. My message is the motor is already broken so make the trans alignment as good as you can to lessen the chance of damaging anything else form that problem You can get the corner welded back on(Tig Welded ) by a competent machine shop, find another junk SB and make a donor out of it Once you find the donor block take both bare blocks to the machine shop and have them fix it I did the same thing years ago a broken BB motor home block that had broken a rod and busted the right front corner of the block off, it didn't hurt the water jacket or the mains,it wasn't in a stress area It didn't even hurt the cranshaft I had another broken block and cut that corner off and had our local Hi Po machine shop weld the new corner on, as far as I know that rascal is still going down the road pushing a big (42 ft)class A motor that a freind of mine talked me out of that motor for He knew the history of the motor and the problems but he insisted that he trusted me and wanted it bad, he had broken the motor in his motorhome and needed complete bolt in a new one, I had fixed that one as a spare for mine so I ended up letting him have it on a deal BTW, my Class a International chassis motorhome proved to be industructable
Re: Running a block w/broken pass side bellhousing mount? [Re: Cab_Burge] #1581019
02/20/14 12:05 PM
02/20/14 12:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Y'know for all the trouble and expense of fixing the block I think he'd be better off just machining a replacement block. Welding a cast iron block is no easy task, won't be cheap and will never have the original strength. Unless its a rare numbers-matching car, I'd seriously consider replacing the block.
Re: Running a block w/broken pass side bellhousing mount? [Re: Stanton] #1581020
02/20/14 12:58 PM
02/20/14 12:58 PM
Pa
Pa
This is not a rare numbers matching car just simply a 340 'cuda with a 69 340 in it. As you can see dowel pin that's been drilled in the block and trans clearly isn't stock. The outline of the original dowel location can be seen just below it. I was tempted to put the original dowel in the trans, then lift up to seat it in the broken area and see if the hole that drilled for a new dowel would actually line up. Basically at this point I have the option of trying to limp along with the 340 or installing a 318 because I'm not in a position to spend 3 - 4k to get a 340 built.
Re: Running a block w/broken pass side bellhousing mount? [Re: 71nonRT340shaker] #1581021
02/20/14 01:09 PM
02/20/14 01:09 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
I had a block like that and I ran it but I had to mess with the alignment as it would vibrate. The only reason I did it though is it was a T/A block in an AAR cuda. Otherwise I would have scrapped it. I think you should be able to get a good used short block someplace for way less than $3-$4k and buy gasket kits and swap your heads and other parts. You could clean and paint everything real nice while you are at it.
Al & Sheila
Re: Running a block w/broken pass side bellhousing mount? [Re: Stanton] #1581022
02/20/14 03:14 PM
02/20/14 03:14 PM
It use to be very hard to get cast iron welded so t would live, not so anymore Especially using a tig welder with the proper rod
Re: Running a block w/broken pass side bellhousing mount? [Re: 71nonRT340shaker] #1581023
02/20/14 08:09 PM
02/20/14 08:09 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Surely will get flak for this, but here goes ...
How about converting one of the other bolt holes into a dowel location?
That way there would still be 2 dowels to locate, just 2 fewer bolts holding things together.
I knew a guy years back in Vt who rebuilt TFs, and had a 67 RT personal car. When someone wanted a beefed 727, he would sell them the one out of his car. Got to be that he only used a couple or 3 bell bolts, 2 crossmember bolts, and I think only a couple converter bolts, could pull the trans in a few minutes.
This would make the 2 lower block to trans braces more important.
It takes gasoline to interest me.
