Page 1 of 3 1 2 3
stepside wheels and tires #1580904
02/18/14 06:06 PM
02/18/14 06:06 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
wondering how tall a tire you can run on the back of a stepside. i have 295 50 15 now and am thinking of going to an 18 or 20 inch wheel after an axle flip. any ideas or suggestions?
Re: stepside wheels and tires [Re: 72d100] #1580905
02/18/14 06:54 PM
02/18/14 06:54 PM
scratchnfotraction Offline
are you do a shackle flip or just flopping the axle on top of the spring as is?
are you tubbing the bed or is it stock tubbs?
I ran 32x11.50x15 on a 10" rim with a 3.75 backset with out rubbing with a shackle flip axle flop.
the 276/60/15 and 295/50/15 on a 10" rim 4.5 backset fit with stock tubbs.
if it was tubbed to the frame with a stock truck width axle a 10" rim with 7.5 backset fit a 29x15.5x15 M/T in the fenders.
so a tall/wide 18-20 should fit a tall fatty in the fenders.
as far as tall goes..I have had 34x9.50x15 on a 8" rim with 4" backset on my stepside with a flip flop.. its up in the fender dead center with stock width truck axle.
do they measure those big rims the same as smaller rims for width/backset???
Re: stepside wheels and tires [Re: scratchnfotraction] #1580906
02/18/14 07:15 PM
02/18/14 07:15 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
im pretty sure they are measured the same way here is the tech sheet for the wheel im thinking about and im thinking an axleflip would be my best bet for now
Re: stepside wheels and tires [Re: 72d100] #1580907
02/18/14 10:31 PM
02/18/14 10:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The way scratch does the flip flop as he calls it only nets about 2-3" of drop in the rear. an axle flip alone is 6". Scratch than does the Shackle flip which lifts it back up 4" as this method is used to raise 4was 4" or eliminate the factory blocks.
Re: stepside wheels and tires [Re: 72d100] #1580908
02/18/14 11:30 PM
02/18/14 11:30 PM
Truckville, the capital of NY
85_Ram_4speed Offline
How tall or how wide? You can go very tall no problem, it's the width you have to watch. But 8" of tread on the grond as tall as 32" should not be a problem if it has the right placement in the wheel well. I have 29" street tires that fit fine (255/70r15).
Outcast Dodge guy.
Re: stepside wheels and tires [Re: 85_Ram_4speed] #1580909
02/19/14 12:01 AM
02/19/14 12:01 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
i was thinking maybe a 275/35 20 or maybe a 295 40 20
Re: stepside wheels and tires [Re: 72d100] #1580910
02/19/14 01:34 AM
02/19/14 01:34 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Both seem to be good choices. The 35 series your considering is close to 28" tall and the 40series is about 29.5" Tall.
Re: stepside wheels and tires [Re: 76dodgeboy] #1580911
02/19/14 10:04 AM
02/19/14 10:04 AM
Huntsville, AL
V
venom107 Offline
venom107  Offline
V
Huntsville, AL
295/40/18 on the back.
Re: stepside wheels and tires [Re: venom107] #1580912
02/20/14 12:50 AM
02/20/14 12:50 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
any fitment issues and what is the backspace on them wheels
Re: stepside wheels and tires [Re: 72d100] #1580913
02/20/14 02:10 PM
02/20/14 02:10 PM
Huntsville, AL
V
venom107 Offline
venom107  Offline
V
Huntsville, AL
18X9.5 wheel with 5.031 in. Backspace. I had a little issue with the inside of the wheel well, but I am running a narrower 8 3/4. it measures 56 3/4" flange to flange. I would think it would be fine on a standard width rear. The inner wheel well issue is now fixed.
Re: stepside wheels and tires [Re: venom107] #1580914
02/21/14 02:19 AM
02/21/14 02:19 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
so im guessing with the 6+ backspace i will probably have to tub it
Re: stepside wheels and tires [Re: 72d100] #1580915
02/21/14 02:03 PM
02/21/14 02:03 PM
E
earlymopar Offline
earlymopar  Offline
E
I'm running P285/70R-15 tires on 8" rims which are roughly 31" tall. I'm not a low profile tire guy, especially on cars that never came with them. These tires look correct and fill up the wheel well much better. My fronts are 235-75s on 7" rims.
- EM
Re: stepside wheels and tires [Re: earlymopar] #1580916
02/21/14 06:45 PM
02/21/14 06:45 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
Rims on the green truck look like boss 338 18x9.5.
I have same size and tire on my barracuda.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: stepside wheels and tires [Re: EV2CUDA] #1580917
02/21/14 09:56 PM
02/21/14 09:56 PM
Huntsville, AL
V
venom107 Offline
venom107  Offline
V
Huntsville, AL
They are the 338.
I would think 295 with a 6" back spacing would work on a stock rear. I am over an inch narrower on each side and have a lot of clearence on the outer fender. As it sat before I tubbed it, I only had a slight rub on the inside on during hard turns. I only tubbed it for future plans. That and I needed a place for my gas cap.
Re: stepside wheels and tires [Re: venom107] #1580918
03/09/14 02:23 AM
03/09/14 02:23 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
has anybody seen the new ridler 645's yet . what would be a good backspace for the front?
Re: stepside wheels and tires [Re: venom107] #1580919
03/09/14 06:38 AM
03/09/14 06:38 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I am a bit confused as to the axle flip netting 6" of drop.
The axle tube is only 3" and with the perch height added would be in the 4" range.
Where do the extra 2 inches come from?
Re: stepside wheels and tires [Re: hp383] #1580920
03/09/14 11:01 AM
03/09/14 11:01 AM
flopping the axle on top of leafs with shackle in stock position would get you 6" drop. IIRC
the shackle flip with axle flop like I do with my trucks will get you 4+ inch drop. giving a lowerd stance and level with the stock front end. depending on # of leafs and arch of spring packs.
Re: stepside wheels and tires [Re: scratchnfotraction] #1580921
03/09/14 01:06 PM
03/09/14 01:06 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Scratch the axle flip is good for 6" but the Shackles flip Lifts the rear 4" so you only have a 2" drop as a result
Re: stepside wheels and tires [Re: hp383] #1580922
03/09/14 07:21 PM
03/09/14 07:21 PM
the extra 2 inches (I don't think it's 2" though) come from the spring pack thickness---you are now putting the axle on top of the spring so you now have the spring pack thickness to account for too.
Outcast Dodge guy.
Re: stepside wheels and tires [Re: 85_Ram_4speed] #1580923
03/13/14 01:55 PM
03/13/14 01:55 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
venom are your wheels 0 offset or the +6?
Page 1 of 3 1 2 3
