Re: stepside wheels and tires
[Re: 72d100]
#1580908
02/18/14 11:30 PM
02/18/14 11:30 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
How tall or how wide? You can go very tall no problem, it's the width you have to watch. But 8" of tread on the grond as tall as 32" should not be a problem if it has the right placement in the wheel well. I have 29" street tires that fit fine (255/70r15).
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1580909
02/19/14 12:01 AM
02/19/14 12:01 AM
Posts: 3,235 Marion Illinois
72d100
Marion Illinois
i was thinking maybe a 275/35 20 or maybe a 295 40 20
[Re: 72d100]
#1580913
02/20/14 02:10 PM
02/20/14 02:10 PM
Posts: 65 Huntsville, AL
venom107
Huntsville, AL
18X9.5 wheel with 5.031 in. Backspace. I had a little issue with the inside of the wheel well, but I am running a narrower 8 3/4. it measures 56 3/4" flange to flange. I would think it would be fine on a standard width rear. The inner wheel well issue is now fixed.
[Re: earlymopar]
#1580916
02/21/14 06:45 PM
02/21/14 06:45 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
Rims on the green truck look like boss 338 18x9.5. I have same size and tire on my barracuda.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
[Re: venom107]
#1580919
03/09/14 06:38 AM
03/09/14 06:38 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I am a bit confused as to the axle flip netting 6" of drop. The axle tube is only 3" and with the perch height added would be in the 4" range. Where do the extra 2 inches come from?
